Aleph 3 Bible - Page 3 - diyAudio
Old 30th March 2008, 10:17 AM   #21
Thanks Grey. I'm going to put a circuit together and see how it goes. Hopefully you will be available to answer questions then!
Greg.
Old 22nd August 2008, 04:23 AM   #22
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Default 9610
Hiii
My friend use irf 9610 for his project
and change it 5 times
as the discusion above irf 9610 & 610
can change with harris / fairchild
Can someone help me to let me know
what is the parts code with the harris
or fairchild
Thank you before for the information
Regards, Jeffry
Old 22nd August 2008, 04:44 PM   #23
hifimaker's Avatar
There's this old thread to consider on Top 10 Aleph improvements:
Top ten ways to a better Aleph
-David
Old 22nd August 2008, 07:03 PM   #24
The one and only
Nelson Pass's Avatar
Default Re: 9610
or fairchild
As I have posted elsewhere, parts from Fairchild, in particular
the 9610, should be tested, as some of them now exhibit the
"P channel anomaly". This is apparently due to Fairchild acquiring
the Samsung production.
Old 25th August 2008, 06:27 AM   #25
Pocoyo's Avatar
Default Just asking a little more
Is that ok if we try to buy FQP 12P20 cause of
different of Id Cont is big : 9.7A (11.5A - 1.8A)
to change irf 9610 ?
(Must be imported first than tested)
FQP12P20 MOSFET, P, TO-220
Transistor type:MOSFET; Voltage, Vds typ:-200V;
Current, Id cont:11.5A; Resistance, Rds on:0.36R;
Voltage, Vgs Rds on measurement:-10V; Voltage, Vgs th
typ:-5V; Case style:TO-220 (SOT-78B); Case style,;
IRF9610PBF - MOSFET
Transistor Polarity:P Channel; Drain Source Voltage,
Vds:-200V; Continuous Drain Current, Id:-1.8A; On-
Resistance, Rds(on):3ohm; Rds(on) Test Voltage, Vgs:
10V; Package/Case:TO-220AB 63J7433;
Regards, Jeffry
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 19 25th January 2014 02:15 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
Newbies - Bible on Sale ralph-bway Multi-Way 1 6th August 2006 04:32 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Copyright 1999-2017 diyAudio
