Hi everyone,
I am new here. I am in the midst of building aleph 4 stereo amp, waiting for pcb boards to arrive. 1. Aleph 4 is biased at 3 amp. Is is ok to use ERSE Super Q USA 2.2mh 14AWG ESQ55 series((up to 20 Amps)) inductor as simple pi filter? 2. Can aleph circuit be biased to class ab? If so which resistors need to be changed? I have very limited knowledge on electronics and replies are very much appreciated. Thnak you. |
#2 |
Also I like to thank http://www.penguinlovers.net/audio/aleph5_proj.html for all the instructions and tips. For mosfet matching I like to thank Diyaudio and Finnis for clear instruction. Most important of all, I like to thank Mr Passlab for his generosity.
I hope I can successfully build this amp. |
#3 | |
The one and only
2) Not really. Theoretically possible, but the result is not pretty.
#4 |
Thank you, Mr Nelson Pass.
#5 |
I did some mosfet matching and realised the my digital meter only gives 3 digit below 4 volt. So I can match irfp9610 to last 3 digit, but with the 240s, I can only get last 2 digits.
So, if I add a resistor in series with the multimeter to bring the reading below 4 volt, will the matching be accurate? BTW: I smoked my finger. I didn't know the resistor for 240s is too hot to touch. Thanks. |
#6 | |
The one and only
voltage drop across an input resistor. When you say 3 digits, do you mean that the voltmeter only resolves .01V or .001V. .01V is enough to match 10 mV on Vgs which is about as good as you can expect.
#7 |
It is .001V below 4 volts. If above 4 volt it is .01 onwards. Trying to understand, .01v should be fine.
Thanks Mr Nelson Pass. Highest Regards. Nicolas |
#8 |
Anticipation turns into anxiety.
Smoke come out from one of the current source irfp240 device. When I first on it, everthing seeems fine. I measure the voltage across the 10k output resistor that is in series with the led and I see smoke. I think I measure the wrong resistor (misreading instruction), suppose to be the 1.5 ohm 5 watt resistor. Have I done something wrong? I change the fuse and it still blows. I test the mosfet where the smoke comes out and it's not toasted. The 1.5 ohm and the 221 ohm resistor is ok too. What shall I do now? Please help me.
#9 |
The one and only
My teleporter has the same problem, so you'll have to give
me usable information for me to help you.
#10 |
Mr Nelson Pass,
I wanted to cry and you made me laugh. I have problem explaining in electonic english, so bear with me. After the smokey senerio, I found one irfp240 that is "connect" to Q3(ZTX240) is dead. Actually, I use the mulitmeter to measure the voltage across the output resister(10K) the is in series with the led, immediately I see smoke. I don't know if that is the problem. I also discover the 1000va transfomer is overheat base on the plastic wrapping on the trasformer partially melted. When I first switch on the amp(one channel) for one minute or two, no smoke. So, I proceed to measure voltage and "smoke". Please tell me what to do ... Please .... |
| Some basic questions..... | astrodog | Chip Amps | 5 | 2nd July 2008 09:18 AM |
| Basic sub/amp questions | Katokahn | Subwoofers | 3 | 1st November 2006 05:03 AM |
| Basic Questions | DarkMage | Multi-Way | 2 | 5th November 2003 02:51 PM |
| Some basic questions... | Ziller | Everything Else | 5 | 13th January 2002 02:49 PM |
| Basic Questions | wnichol | Solid State | 4 | 16th November 2001 04:59 AM |
| Page generated in 0.10713 seconds (78.03% PHP - 21.97% MySQL) with 11 queries |
