Nelson,
You have used thermistors in the bias circuits of the 400/4000 and stasis amplifiers and even more recently than that. My questions are these: 1) It is my understanding that the heating of the thermistor varies the bias current in the output transistors to offset heating effects. Is this so? 2) Does the thermistor self-heat or is it heated by it's environment or both. If both then which effect dominates. Thank you. Graeme |
#2 |
The one and only
The thermistor is used to provide temperature compensation
on the output stage, the goal being to reduce the bias drift with temperature and provide a faster warmup for the amplifier. The self heating of the thermistor is negligible.
#3 |
some where in the aleph' s user manuals as well there is a mention of thermistors being used to isolate the signal ground and the power ground.
what is the relationship between the grounding parameter and temp? thks |
#4 |
Unless the circuit malfunctions, there's no temperature to worry about. Only if there is a circuit fault of major proportions does the part carry any significant current. Otherwise the part functions as a low-value resistor.
Grey |
#5 |
The one and only
The nice thing about using a thermistor as a ground conductor
is that usually it's around 5-10 ohms, but if a lot of current starts to flow, the resistance is reduces. Of course in a production situation you need to test the fuse versus the thermistor in a fault condition to ensure that the fuse croaks first.
| Thermistor help | luvtheoldschool | Parts | 5 | 4th February 2008 12:56 PM |
| help with ntc thermistor | jarthel | Parts | 4 | 1st October 2006 04:57 PM |
| thermistor | larryg | Solid State | 15 | 21st October 2004 03:40 PM |
| Nelson X3 arrival questions | Addicted Help!! | Pass Labs | 45 | 30th April 2004 06:57 PM |
| Is it mystery .... ? Questions to Nelson | nar | Pass Labs | 14 | 23rd July 2003 07:15 PM |
| Page generated in 0.08414 seconds (71.59% PHP - 28.41% MySQL) with 10 queries |
