Here is my Mosfet frontend. I am having trouble in testing. Q3 and Q4 get very hot! I measured 2.0 volts across R5 which means it is passing about 10mA. What is happening? Do i need to load the drives, and or tie the Fb in? I think it is possibly oscillating.
Please help with this! DonS |
#2 |
The one and only
Check the voltage across R16. If each LED is 4 volts,
then you will have something around 8 volts across R16, meaning that about 80 mA is passing through the output devices, and at 75V rails, that's about 6 watts per device, which is quite a bit.
#3 |
Each led is 1.8v X 3 = 5.4v
Voltage across R16 is 2.02v Current should be about 20mA If the full rail is on the collector of Q4 max power should be 3 watts. Voltage across R16 continues to climb as it warms up. |
#4 |
This may help. When R5 was 560 ohms there was no voltage across R16. I increased current in the diff pair to help turn Q6 on.
DonS |
#5 | |
use just one led string for both Q3 and Q4 also - you can reference leds to +Ub (recalculated R6 or R14 to +75V, not gnd)
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#6 |
Sorry for these short replies. I have to allow the components to cool down between tests.
Drive + is 61 volts Drive - is 58 volts I hope this helps. DonS |
#7 |
Zen Mod are you saying that is the problem. I kept them independant so they would have a wide range of separate options for each current source.
DonS |
#8 |
R14 is now open, and Q4 appears to be shorted.
I think Q6 was full on! DonS |
#9 | |
first- make Iq through Q4 fixed , for start then (besides already mentioned idea to share led string for both CCS biases) recheck value of R1 ( you need ~ 4V Ugs for open throttle of Q6......but you don't need much more) so - make R5 from one fixed resistor and trimpot in parallel- so you can tweak " openess" of Q6. tweak that value looking at other DC voltages in circ DC potentials of drive points are nothing more than result of transposed DC characteristics of Q5 thingie (some called it Vbe multiplier probably,but I'm dumb for that ) . btw- sharing bias net for two CCSes on same side is benefitial from more than one reason, but I'll mention just one- less temp-co induced differences
#10 |
Very cool front end - it looks a lot like the A75 front end, only SE.
JJ |
| Amp. troubles PLZ HELP!!!! | ReverB | Car Audio | 5 | 1st November 2009 01:11 AM |
| A noob, with troubles | deyjavont | Introductions | 2 | 21st August 2008 01:51 AM |
| Tube frontend.... | Skorpio | Tubes / Valves | 1 | 6th April 2006 02:19 PM |
| SW troubles... PIA | nunayafb | Multi-Way | 7 | 30th March 2006 12:04 PM |
| amp troubles | squid6 | Tubes / Valves | 5 | 8th July 2004 06:50 AM |
| Page generated in 0.11269 seconds (80.95% PHP - 19.05% MySQL) with 11 queries |
