Eagle files
eagle is confusing me sometimes too because it does not want to open files from other versions ie if the file is saved on ver 4.01 only that ver wil open it i think so
correct me if iam wrong
i have eagle 4.01 , 4.03 4.09 installed so iam able to open most of eagle files posted but another important thing is to have all the libs same sa author ie if zomeone added something to library and posted the project then you need to have the updated library - that is confusing
I have EAGLE 4.09r2
I have EAGLE 4.09r2
But I have only used it a couple of times.
So I have not learned it well enough to tell so much.
Most who use it says it is a good circuit program.
One of the best FREEware.
I have some other free student version
of 2-3 other Cicuit Makers program.
Micro Cap 7.0
SW Cad III 1.15d
CircuitMaker 6.06
Eagle 4.09r2
I can not say I have used any of these more than a few times.
I still haven't found any good Circuit Drawing Program
with an easy "One click and drag" function
for to create transistors, resistors and caps.
They just don't exists yet, I would think.
Most programs OVERDO it, making things hard to use.
Better few functions, that works perfectly easy
than 100reds of options, that requires 5 different
mouse actions to find/get.
Nelson Pass is a man, who likes KISS.
Keep it simple.
;) He might be the man to recommend something right for us amateurs. ;)
Those "SPICE-men" are way over our heads...
/halo - NOT impressed by Cicuit Drawing Software Designers. :mad:
i have aleph 5 schematic in a progress i will post it but it needs some work on it - maybe monday? anyways to create a schematic do file> new > schematic
for better help with eagle
go there
http://www.cadsoft.de/cgi-bin/downl..._public/download.htm.en&dir=pub/userfiles/doc
and download english pdf manual
it is really helpful i learned alot from it
if you need eagle 4.03 it is here
http://www.malachowski.com.pl/admin/passlabs/eagle.zip
halojoy, i was impressed by your thread about czech republic hifi make sure to check www.gmx.cz for more
i live 500meters apart from chech border they have excellent beer also
xsnailx/ drinks czech beer now - r"radegast"
Eagle will give error reports if you try to open files made with "cracked versions" - registered with keygen produced serials. Also if you use cracked one, you will be able to work on your files and save them, but when you try to open them next time you will also get error reports.
