Aleph-x hot source resistor
Old 17th July 2007, 03:30 PM   #1
globalweb is offline globalweb  Sweden
Default Aleph-x hot source resistor
Hi
Iím half through starting up my Aleph-x (100 w). The problem I have right now is one of my source resistors is getting to hot, over 90 C. Voltage over them, its four resistors is if I remember it correctly 0.54 V. Iím not with the amplifier right now.
Iím sure the solution is out there and Iíve spent yesterday going over treads and Iím going to look for it. But if you know what the solution is it would help me a lot.
So far I have come up with the following possible faults.
- Problem with the PCB. I donít think so because Iím using this board: http://www.kk-pcb.com/amps.html . It should be ok.
- A broken mosfet- hopefully not. I donít want to resolder it again for the fifth or tenth time.
- Badly matched mosfet- hopefully not. The voltage over the source resistors are the same.
- Maybe there something with the bias current- I havenít looked in to that yet.
- Broken silpad
- Bad soldering
Maybe all the source resistors have more then 90 C. I have to look in to that.
Anyway itís not ok.
I have more question but I think Iíll leave it for later.
Old 17th July 2007, 03:33 PM   #2
Magura is offline Magura  Denmark
Magura's Avatar
90C for a power resistor is not all that hot....
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 17th July 2007, 07:46 PM   #3
The transistor was 75 C. Much hotter then the others.
Old 17th July 2007, 11:21 PM   #4
Magura's Avatar
then try replacing the fet that runs warmer, but keep the initial installed fet to be able to put it back if there is no change.
Magura
Old 18th July 2007, 04:37 PM   #5
tze-hao yen is offline tze-hao yen  United States
Send a message via MSN to tze-hao yen
one time i did the some mistake
i wire the g directly to the resistor and the resistor got hot so you can try to find out about the wireing you have
Old 19th July 2007, 03:15 PM   #6
Right now Iím waiting for a new PCB. The old one has been re soldered too many times.
Old 19th July 2007, 03:26 PM   #7
Aleph-x hot source resistorHide this!Advertise here!
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 01:55 PM
Aleph 2 source resistor comparison? tomchaoda Pass Labs 11 19th July 2004 07:20 PM
Aleph 5 source resistor voltages Keith Marrison Pass Labs 3 7th July 2004 07:49 PM
please HELP bourned Source resistor Aleph 30 wijgers Pass Labs 3 12th April 2004 09:35 PM
Copyright ©1999-2017 diyAudio
