Here my Pass Aleph 2 and UGS diy A2 : Expensive Heatsinks from Seem-Semrac Size : 300 x 200 x 75 mm with 19 mm base plate PSU Transformer 2x35V 1KVA (local manufacturer) Two rectifiers with MUR3020WT Onsemi 22000µf - 2,2mH – 2 x 22000µF - 4,7µFMKP (63V electrolytic caps) U=49 V (more than 45V of original schematic). BIAS is adjusted to 2.8A to keep heatsinks under 60°C. Offset adjusted to 0mv (+/- 0,3mV) with R11 (thanks Cheff ! I used some audio parts : 220µF capacitors Elna Silmic II, MOX4 resistors and Kiwame resistors but I can’t say if it sounds better because I don’t test standard ones. PCB from PCB-Design ZTX 450 instead of MPSA18 (I don’t know why, I have MPSA too but I don’t test) DC protection and delay 6s with a Velleman K4700 kit. The blocks (37 kg each) are built with polish stainless steel. An “U” prevents electronics parts from hot temperature. In fact, heatsinks are out of the box --> 55-60°C max for heatsinks, 24-26°C max inside, better for capacitors’ life time (I hope). UGS : Exactly as proposed by Cheffdegaar here. I simply used Cheff’s prototype PCB and added a mechanical selector and 4x10Klog ALPS potentiometer at output. Cheff gives all is necessary to built one easily (schematics, pcb draw … and help too). Just one difficulty: to find the Toshiba Jfet! I put a second potentiometer in case of balance adjustment becomes necessary (not used actually). It’s difficult for me to describe the sound in English. UGS and Aleph2 give wonderful results. Natural sound, a lot of details, marvelous rhythm based on deep and rapid bass and lovely high frequencies. The power reserve is appreciable too and I sometimes use no reasonable volume level . Very pleasant I find!A heating period, 45min-1hour minimum is needed to get the best results. Unfortunately, all is not perfect : - Sometime the big toroïds make variable bzzzzz like neon tube lights. I tried to intercept a 230V-230V transformer between wall connect and amps but the bzzzz continues. I tried a DC-blocker too but without result. I suppose the noise is not due to DC inlet. The transformers are probably bad quality, I suppose. - The heatsinks get very warm of course (55-60°C) and my little room (15 m²) becomes slowly a sauna when the amp runs a long time. So I can’t use this amp during summer, too uncomfortable I regret not insert standby mode (reduced BIAS) and not to limit the power to 50W (Aleph 5 for example instead of 2). I have to find another solution for summer, built a cold amp later … I sincerely thank Mr. Pass for generosity and the quality of his amps. Thanks Cheffdegaar too and others guys for precious advices and help Laurent |
#2 |
A2
#3 |
A2- front
#4 |
A2-03 feet
#5 |
A2 - Inside 1
#6 |
A2 - Inside 2
#7 |
Some pictures of preamp
#8 |
preamp - over
#9 |
Preamp - rear
#10 |
Preamp Front
| Pass Aleph 0s | GRollins | Pass Labs | 1 | 2nd February 2010 07:57 PM |
| Pass 350.5 vs aleph | daly41k | Pass Labs | 8 | 19th March 2007 03:19 PM |
| Pass Tharagard A75 vs Pass Aleph 1.2's | daly41k | Pass Labs | 7 | 18th February 2007 03:10 PM |
| Aleph-p 1.7 VS Pass X2 | peter7 | Pass Labs | 5 | 24th April 2005 03:06 PM |
| pass aleph P VS pass X2 first version | perusicchio | Pass Labs | 10 | 5th March 2004 10:06 AM |
| Page generated in 0.11447 seconds (82.76% PHP - 17.24% MySQL) with 11 queries |
