Advice for Linkwitz Orion system with Nelson Pass-style pre-amp and amp
Old 26th November 2007, 09:17 PM   #111
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Originally posted by Tazzz
Why not incorporate coils aswell?
http://www.steinmusic.de/audiofino/bauteile-spulen.html
Or would perhaps trading opamps for ferrite in the signal path be a bad swap.
I used coils to make LC notch filters for the electronics on my
full range w/ woofer systems. Simple and nice replacement
for equivalent op amp circuit. They have some nice 100 mH
type parts in the Digikey catalog.
Old 27th November 2007, 03:17 AM   #112
DougL is online now DougL  United States
I for one would find the process very educational.
Several things are very clear to me.
Any acceptable design would be plug compatible to the ASP.
Second, I started audio in the 741 eara, so my intuition is that a simpler, discreet implimentation would be both estetically and sonicly superior. YMMV
My goals are first to learn, second great sound.
I have a 3 way OB on a DCX, and would very much like to have an option to migrate to a analog active crossover.
Thanks in advance.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 20th December 2012, 06:31 AM   #113
fbee is offline fbee  Germany
Default F5
....now end of 2012 . LX521 follows Orion.
I wonder if F5 (turbo? v1,2,3?) would be a good match for the new LX521. (Gain of F5 is only 15db iso the recommended 26db)
Maybe the woofer channel could be done with hypex modules (more power reserves) and mid/tweet with F5?
Old 21st December 2012, 01:55 AM   #114
audionut is offline audionut
For my bi-amped system, I use a BOSOZ which drives a line level analog crossover consisting of coils and capacitors..the crossover terminates into Aleph J's...
This all replaced an active Marchand crossover which was heavy on Op Amps.
I much prefer the sound of the simple coil and capacitor filters. As diyers, we can do this because we know what the impedences of the stages before and after the filter.
The BOSOZ is very cool in this application because the BOSOZ lets you adjust the gain of the high and low channels without changing the output impedence of the preamp channels. (the analog filters would be affected if the output impendance of the BOSOZ changed as you adjust levels) So you can change levels of the high channel and low channel to suit your taste.
The sound is simply natural and exquisite.
Old 21st December 2012, 09:39 AM   #115
Default Amp Recommendatio
Interesting...
but for the time beeing, I' m only looking for a suitable amp
F5? F6? ....????
Old 21st December 2012, 11:41 AM   #116
Barleywater is offline Barleywater  United States
fbee:
SL if clear on amplification. He recommends power levels, that amplifiers all have same gain; and logical extension is that all amplifiers have identical response, easiest when amplifiers are identical.
Old 21st December 2012, 11:53 AM   #117
so maybe a 8ch F5 ?
Old 21st December 2012, 11:54 AM   #118
hochopeper is offline hochopeper  Australia
Originally Posted by Barleywater View Post
fbee:
Surely amplifiers of different power amplifier gains could be used rather than using the atten/gain stages of the ASP - http://www.linkwitzlab.com/images/gr...asp-blocks.gif
Old 21st December 2012, 12:07 PM   #119
Yes, but assuming plug and play of speaker system without measurement/adjustments requires matched gain.
Old 21st December 2012, 12:21 PM   #120
assuming 8ch F5 could be built with
F5 v3 for the woofer channels
and F5 v1 for the mids/tweeters?
Same gain for v1/v3
Advice for Linkwitz Orion system with Nelson Pass-style pre-amp and ampHide this!Advertise here!
Linkwitz Orion x-over pcb's 2 for 1. Tristanc1 Swap Meet 4 26th March 2007 08:01 PM
linkwitz orion x-over pcb's Tristanc1 Swap Meet 0 8th February 2007 02:56 AM
Linkwitz-style **M baffle ? rick57 Subwoofers 8 12th December 2004 07:46 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
