Advice for Linkwitz Orion system with Nelson Pass-style pre-amp and amp
Old 25th November 2007, 03:44 AM   #101
LineSource is offline LineSource  United States
LineSource's Avatar
This JFET opamp circuit was developed in diyAudio threads as a clone of the circuit used in Nelson Pass Xovers. The Pass SuperSym amps favor +/- inputs, so an additional JFET opamp with single ended-input and dual ended outputs would need to be developed. LTSPICE schematics would allow team development and data comparison.
Old 25th November 2007, 04:32 AM   #102
jnb is offline jnb  Australia
This is what I mean. The following circuit combines my driver resonance management, a notch filter, baffle/dipole compensation and a second order filter all in one for a flat mesured in room response to within +-2dB from 25Hz to two octaves above the crossover point (800Hz).
There is also a volume control and it does not affect the frequency response at any position in it's travel.
Old 25th November 2007, 08:43 AM   #103
davidespinosa is offline davidespinosa  United States
Default Re: SL's response to O'Brien ASP
Originally posted by Tosh
...and he said just don't call it 'Orion'...
Publishing an alternative XO in the public domain will encourage people not to pay SL's design fee. So we shouldn't do it without real permission. I think the alternative XO is more likely to happen if we face the ethical issues head-on.
Personally, I'm not against lots of op-amps, but it would be very cool to see how to combine filter stages.
Perhaps SL and Nelson can work something out -- they actually live fairly close together.
David
Old 25th November 2007, 06:25 PM   #104
F1 FAN is offline F1 FAN  Canada
While it does not reduce the number of stages and spacing may be a hurdle, is it possible to use the stock Orion PCB and design small (maybe vertically oriented)adapter boards with a pair of these JFET opamps that would fit into the DIP footprint?
Old 25th November 2007, 06:36 PM   #105
KSTR is offline KSTR  Germany
KSTR's Avatar
Default Re: Re: SL's response to O'Brien ASP
It has been said (here) how to get there.
All you need to know is the target transfer function (expressed in the Laplace notation), then try to approach**) that with stages with interacting/non-ideal networks, looking at the mag/phase errors. Probably best split into minimum-phase and allpass sections. From what I see on SL's infos about the Orion (and the Phoenix) the transfer functions are already there, albeit not in direct Laplace notation (not a problem, though).
**) that is, empirically optimize, after using first order (non-interactive) guesses.
See andy_c's Website for details of this technique (on a way less complicated example), using LTSpice.
http://andycpublic.50webs.com/phono_preamp.htm
You can nest parameter sweeps three levels deep, thus you can quickly see how close you can get with a certain parameter shift and how sensitive it is. It will most certainly be a lot of trial and error work...
Just my 2 ct., Klaus
Old 26th November 2007, 01:39 AM   #106
kropf is offline kropf
Default two paths to progress and another idea
The path forward seems clear:
1) Define the transfer functions, then come up with circuits to approximate them. Unless the transfer functions are plundered strictly from the public information on the website, I would be, and it sounds like others may also be uncomfortable using the information. Unfortunately, it is much more difficult to design the network to approximate a more general function.
2) Develop discrete op-amps to plug into the circuit - either as drop-ins for op-amps in the original circuit or for specific functions in a modified circuit
3) And now the "new" idea. You could run the circuit at line level rather than from the output of a volume control pre-amp. This reduces dramatically the required dynamic range of the signal processor. Place the volume control on each output signal. If it is single ended, the volume control would only be 50% larger than a balanced-stereo volume control implemented on circuits such as the P1.7.
Unless you try to implement some of the transfer function in the op-amp internal circuitry, the first two are independent. The third would allow you to move the relative level adjustments to the end of the processing chain and may change how the transfer functions are defined.
Jeremy
Old 26th November 2007, 02:16 AM   #107
I might add that I put my volume control where I did for unrelated reasons, and I only included it in this discussion to make a point about interactions.
Old 26th November 2007, 01:00 PM   #108
john k... is online now john k...  United States
john k...'s Avatar
To be perfectly honest, having played around with the my NaO circuits at length, and having built the Orion with both original and simplified active crossovers I don't think there is that much to be gained through this. As I said previously, it doesn't hurt the system to simplfy the circuits, but I'm not sure much was gained other than a cost reduction. And I would suggest that it is possible that a redesign could just as well take something away from the system.
If you want to improve on the performance of the Orion, maybe the ASP isn't really the place too look. Maybe you should look at the Orion overall and determine what its limitations are and then start with a clean sheet of paper addressing all those factors.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 26th November 2007, 07:03 PM   #109
eLarson is offline eLarson  United States
eLarson's Avatar
From a technical standpoint and particularly a sound quality standpoint, you are probably 100% correct.
However there are still two things to be gained: the knowledge and the fun of the exercise.
We are talking Do It Yourself, after all. I mean we do this for the fun of it, right? If it wasn't fun, why would we bother?
eL
Would a woodchuck bother to chuck MDF?
Old 26th November 2007, 10:09 PM   #110
Tazzz is offline Tazzz
Why not incorporate coils aswell?
http://www.steinmusic.de/audiofino/bauteile-spulen.html
Or would perhaps trading opamps for ferrite in the signal path be a bad swap.
Advice for Linkwitz Orion system with Nelson Pass-style pre-amp and ampHide this!Advertise here!
Linkwitz Orion x-over pcb's 2 for 1. Tristanc1 Swap Meet 4 26th March 2007 09:01 PM
linkwitz orion x-over pcb's Tristanc1 Swap Meet 0 8th February 2007 03:56 AM
Linkwitz-style **M baffle ? rick57 Subwoofers 8 12th December 2004 08:46 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 01:39 AM
