diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Mini-Aleph Heatsink size ??? (http://www.diyaudio.com/forums/pass-labs/104610-mini-aleph-heatsink-size.html)
patoff 3rd July 2007 08:07 PM
What is the minimum size for each mini-aleph xtor passif heatsink for 15V rail PSU?
Standard Socket 370 CPU Heatsinks without Cooling Fans, is it good?
P.s.: Sorry for my engish, I'm a French-speaking
vdi_nenna 4th July 2007 02:05 AM
That's probably too small. My mini-a's heat sinks are approx 150mm x 430mm x 50mm per channel at 1 amp per channel. It runs very warm.
A way to test if it is too hot- if you can hold your hand on the heat sink for a few seconds without discomfort it is ok. If you can't hold your hand on the heat sink at all, even for 2 seconds, it's too small a heat sink.
Hope this helps,
Vince
patoff 4th July 2007 01:34 PM
Thanks vdi_nenna
I try to find a bigger heatsink
ssmith 4th July 2007 02:31 PM
Not very scientific, but for ideas have a look at the gallery on the pass diy website:
http://www.passdiy.com/gallery-misc.htm
Resources saved on this page: MySQL 18.75%
