Old 26th June 2007, 03:49 AM   #1
jarthel is offline jarthel  Australia
Default +/- in and out on the aleph-p 1.7?
I have found a schematic of the aleph 1.7 preamp somewhere in the net.
Can someone tell me what is the purpose of the +/- in and out in the schematic?
Thank you very much
Old 26th June 2007, 05:50 AM   #2
Stefanoo's Avatar
the + and - are the balanced output, since the preamplifier is made on a balanced topology that you can use also as single ended configuration by shorting the - input of the pre.
For the board, i have designed it and it looks very nice...at least to me...but i still haven't gotten the chance to etch it....i will do it as soon as i'm done with the aleph ax board so that i can make both of them....i think in the next days i'll be done and ready to attemp at the etching of the boards.
Stefano
Old 26th June 2007, 08:21 AM   #3
can you please explain what you meant by balance? Does that mean if I used a "balanced" topology, I need to 2 stereo PCBs?
also you have said "single-ended config by shorting the -in". do you mean connecting a wire from -in to ground? also does that mean I will ignoring the -out?
Thank you for the help
Old 26th June 2007, 09:38 AM   #4
Stefanoo's Avatar
It depends!
You could have just one board for a balanced topology 2 boards 4 boards.
It depends, how the circuit was layed.
I use 2 bords: one per each chanel.
About single-ended, you connect the - input to ground and i think that your output will be + and - (- as ground) but i'm not super sure about this, better wait for more experienced guys's replies.
Stefano
Old 27th June 2007, 12:02 AM   #5
can someone confirm which in/out point must be ground for unbalanced usage?
Thank you.
Old 27th June 2007, 12:09 AM   #6
Magura is offline Magura  Denmark
Magura's Avatar
That's right
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 27th June 2007, 12:26 AM   #7
Originally posted by Magura
That's right
Magura
just to verify: unbalanced operation: both - in/out are grounded?
Old 27th June 2007, 12:38 AM   #8
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
That's right
Magura
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 27th June 2007, 02:46 AM   #9
thank you very much
Old 27th June 2007, 06:35 AM   #10
Stefanoo's Avatar
The Aleph P is a balanced pre amp and would give you its maximu by using it as a balanced pre.
Therefore, if you want a single ended pre i suggest you to build the L version, just thought!
Stefano
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.10431 seconds (78.26% PHP - 21.74% MySQL) with 10 queries
