Old 27th January 2003, 12:57 PM   #1
costiss's Avatar
Default transformer al5
what should the pass aleph 5 transformre r rating be ??(voltage+power)
Old 27th January 2003, 01:00 PM   #2
wuffwaff's Avatar
Costiss,
25-27 volts secondaries, 300-600VA per channel.
william
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 27th January 2003, 05:40 PM   #3
piewie is offline piewie  Belgium
i've allready started building my aleph 5, but i'm using two
750VA 30-0-30 transformers, will this give a problem concerning the voltage?
Old 27th January 2003, 06:20 PM   #4
xsnailx is offline xsnailx  Poland
xsnailx's Avatar
Send a message via AIM to xsnailx Send a message via MSN to xsnailx Send a message via Yahoo to xsnailx
i have 650 va 2*28v
30 v should be no problem
Old 28th January 2003, 12:15 PM   #5
costiss's Avatar
and now comes the grand great question... downscaling this wonderful (i once heard an original...) amplifier to one pair of irf244...is it possible? how much would this output? 20w, i suppose..or? would 64000uF of capacitance be enough in sucha case?
2nd q. ....do regulated supplies like..say the ML2 one (+/-32v) work in this???
3rd ...how much drive rms is required to drive them into full power?
Old 28th January 2003, 05:20 PM   #6
panos29 is offline panos29  Greece
panos29's Avatar
Send a message via ICQ to panos29 Send a message via Yahoo to panos29
Geia soy Costiss!
Loipon,
Its very possible to do so, as far as you do not exceed about 40W on each mosfet, but in such a case i would personally build the ZenV4. I allready have both and my taste is towards the V4.
My aleph clone is about 30w and my V4 about 17W. At least on my tannoys 15 HPD the V4 is more musical although marginally less "bassy", but the mid region is super to say the least! Driving requirement is more than conventional amplifiers and you should have around 2 volts for full drive (on aleph about 1,5)but most modern preamplifiers will do that, I use a diy aleph L . The aleph transformer I use is a 680W toroid with split secondaries of 2X24Vac, under load the dc output is +/-27,5V and bias current 2amps in winter and 1,5A in summer. Willing to help you in any way(I know all local "hidden" sources), just email me panos29@yahoo.com
Panos
Using mains transformer as output transformer Elias Tubes / Valves 175 3rd November 2009 08:36 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 10:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.09000 seconds (70.07% PHP - 29.93% MySQL) with 10 queries
