Attenuating input gain on X amp? Attenuating input gain on X amp? - diyAudio
Old 7th June 2007, 05:21 AM   #1
jeffjazz is offline jeffjazz  United States
Default Attenuating input gain on X amp?
I have a Modwright SWL 9.0 preamp which gain is too hot for my Pass Labs X-150 amp. I only have usable volume range to 9o clock. Is there any way to reduce the gain on the inputs of my X150 without affecting sonics? Dan at Modwright suggested I could increase the plate resistor value from 100K to 200K to reduce gain by 3db in the preamp (but this may affect bandwidth at higher frequencies). I don't know if that would be enough. I am using the single-ended inputs on the amp since the preamp is not balanced.
Any solutions from the experts? Thanks
Old 7th June 2007, 07:21 AM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Default Re: Attenuating input gain on X amp?
try using 4K7 to 22K resistor instead shorting plug on XLR pins.....
I just presume that's way to unbal connection on your amp
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 7th June 2007, 07:34 AM   #3
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
I use this method for my SRPP tube pre to attenuate the gain at the output. R1=4.7K/R2=22K, or R1=22K/R2=4.7K or you could use different values for your purpose.
Old 7th June 2007, 02:39 PM   #4
Babowana's Avatar
Hmm . . .
This one shows better.
Attenuating input gain on X amp?Hide this!Advertise here!
Complementary Input Gain = 10000 !!! lineup Solid State 6 11th December 2008 06:35 AM
attenuating...... Lostcause Everything Else 6 27th November 2008 02:16 PM
Feedback/Correction on Gain rather than input? pilli Everything Else 1 18th September 2008 09:52 AM
Reduce Input Gain Question? mgreene Chip Amps 9 27th April 2004 11:32 AM
Attenuating Power Supply? ghetto Solid State 9 31st July 2003 01:05 AM
Copyright ©1999-2017 diyAudio
