| Thread Tools | Search this Thread |
#591 |
The 2N3820 would be the equivalent P-version.
But that is only theoretical, I do not know how good they are compatible in practice.
/alohka/ |
#592 |
Thanks, Thijs, for that series of tests. I will try to make a 2N3819 version as soon as time (and outside temperature) permits.
Did you do some critical listening yet? all the best
/alohka/ |
#593 | |
Much higher capacitances in the 3820, but otherwise they seem fairly complementary, judging from the rudimentary datasheets I have found. |
#594 |
No listening tests yet... but I should defenitely do that ... the distortion character will change dramaticly when you adjust the power supply for low THD.. from allmost 100% second harmonic, to allmost 100% third harmonic....
PS I also wondered about a 2N3819 complementary... so a bought a few and just received 50 2n3820 JFETs in my mail box today... 0.10$/piece |
#595 |
So ... because this Optimum Voltage, 2nd harmonic canceling, thingy that Nelson suggests works so marvelously... I got thinking...:
I have just completed a Pacific RIAA pre (with the MC pre) amplifier last month or so, and judging from my measurements, the suggested supply voltages are WAY to high.. so I hooked it up to my HP 339A (my pride and joy).. here goes: Power supply +24Volt, as the circuit suggests: 1mV input, 400mV output, THD = 0.3% , purely 2nd harmonic now with optimum power Supply + 13.7Volt 1mV input, 340mV output, THD = 0.0485% , purely 3rd harmonic Yep...
#596 | |
Paper mache horn fabricator
Can you draw me a picture? I'd like to see how you graph this out in order to cement, or jack-hammer, my ideas on how this is done. I've been using the ID/VDS graph and adjusting my amp's values until the transistor's voltage/current falls on one of the graph's curves. Is this correct? Many thanks,
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com |
#597 |
The one and only
Think about it as presented in ZV9. Working the load line is
something that the smarter tube guys have done for a long time.
#598 | |
Thanks Nelson,--this is so cool! When simming out a schematic that employs the LU1014D jfet, I've been staying on the lowest VGS curve and adjusting my voltage/amperage to match that curve. That's what got me to wondering about the mosfets--could it be the same? It's weird how much amperage some of the mosfets must have to stay on a VGS curve--I'm thinking IRFP044N as an example. When tracking the lowest (4.5V) curve, I have to have about 6 amps for anything over 10 volts. That's a lot of amps to add to the bias. The big, bad situation I can't always resolve occurs when the bias wattage is around 100 watts per device! To keep the IRFP044N linear, I have to run high amperage, but low voltage... or switch to a mosfet that's more suitable. Still, I have a bunch of these guys, so I'd better learn how to do this.
#599 | |
The one and only
there. |
#600 | |
Hmmmm, I was wondering about that too this mornig... I have an original Bridge Of Zen, and I can manipulate the Voltage supply with my variac...Would like to see what happens t'night....
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| mhouston |
| JFet BOZ | Tyimo | Pass Labs | 14 | 30th April 2006 03:18 PM |
| Can I replace BF245C JFET with J201 JFET? | bigmike216 | Parts | 2 | 7th December 2005 06:50 AM |
| How to use Jfet? | lumanauw | Pass Labs | 5 | 7th April 2005 03:12 AM |
| Page generated in 0.09088 seconds (68.83% PHP - 31.17% MySQL) with 11 queries |
