Jfet BOZ - Page 55 - diyAudio
Old 25th April 2008, 03:42 PM   #541
Your only 20 years ahead of me in the race called life, he he.
""Pacific " preamp"? don't know what that is, care to enlighten or is it one of those things I should use the magical search button for, or that I should know as an "audio guy".
BTW, I get to play a little today since it is the weekend, I will see what all I can do. Parts are running a bit thin, time to hit up Mouser and Digikey again.
Cheers
James
Old 30th April 2008, 02:45 PM   #542
Tolu is offline Tolu  Germany
Tolu's Avatar
I am thinking about using a LithiumPolymer-Accu as PS for the JFET BOZ. The values are 18.5V or 22.1V and 2.2 Ah. What do I have to put between the accu and the BOZ. Only a voltage regulator or some caps too?
How long will the JFET BOZ play with two 9V blocks?
Old 30th April 2008, 02:54 PM   #543
DaveM is offline DaveM  United States
DaveM's Avatar
I am using standard alkaline cells. I have gone through several sets of batteries because I have forgotten to turn it off. 4 year old grabs your hand and drags you out of the room. You come back in 2 days later to listen no pre-amp. With that, my first set lasted a couple months before I stated to notice increased distortion at volume.
Old 30th April 2008, 04:22 PM   #544
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by JPeitzman
Pacific preamp?
Le Pacific is a JFET/BJT/Tube hybrid, google for bonavolta.ch
(Zenski is younger than me AND a relic, there's hope for me yet)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 30th April 2008, 06:57 PM   #545
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 30th April 2008, 06:58 PM   #546
Zen Mod's Avatar
Old 30th April 2008, 08:20 PM   #547
Oops again, me confuse with the Hiraga Pacific, beat me with a frozen leg of lamb.
(btw, you'd like Mr. Walther, piccy of the gentleman here )
Old 30th April 2008, 08:28 PM   #548
Zen Mod's Avatar
Oops again, me confuse with the Hiraga Pacific.
(btw, you'd like Mr. Walther)
btw - there is one for ya , bloody millionlinguaboy :
http://ndaviden.club.fr/index.html
looki lookie for L'Audiophile scan cds ;
40 heuristick greenies will give ya ultimate virtual pleasure .........
I'm sorta shilly shally ....... frenchie isn't even my last Engrish .......
Old 2nd May 2008, 02:44 PM   #549
Hmm... something else simple I may have to build up. It bears a passing resemblance to the JBOZ. I am about an hour and a half from home and will be for the next few days so I can't tinker at all Though I ordered some parts for the JBOZ and it's power supply that, with a little luck, will be on my door when I get home. It's coming along with some parts for a 300B monoblock build that is my long-running summer project. That is if I don't get side tracked with something like a Aleph-J or JFET buffered Zen V.4. Thanks a lot Master Pass, with this simple circuit you have gotten me hopelessly addicted to JFET's! I never knew a JFET in a simple circuit like the JBOZ could sound so amazing. I might have to give it a try but I have a feeling that a single BJT will not sound as good. Of course it could be that little bit of Zen magic that makes it's way into every Pass design, turning the ordinary into something very very special. At least my JFET addiction will be a little bit cheaper to feed compared to my tube addiction.
BTW I have a small stock of old 2N4220 JFET's that I might give a try in this amp, any thoughts. They are in little TO-72 cases with a fourth pin to ground the case. My dad used them in the industrial work that he did, they where for very sensitive low-level signal inputs. I guess I will just pop them in and fire them up, test it the old and fun way.
Cheers
James
Old 8th May 2008, 07:45 AM   #550
Tolu's Avatar
Hi
I want to build an output stage for the Playstation 1 with the JFET BOZ. Therefore I need only 9 to 12 dB gain. How can I achieve this? What parts do I have to change?
JFet BOZ Tyimo Pass Labs 14 30th April 2006 03:18 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
How to use Jfet? lumanauw Pass Labs 5 7th April 2005 03:12 AM
Copyright ©1999-2017 diyAudio
