Jfet BOZ
Jfet BOZ
Old 14th June 2007, 05:42 AM   #261
Vix is offline Vix  Yugoslavia
Vix's Avatar
Originally posted by Nelson Pass
OK, I won't. I do have something different, though.
I knew it!
Originally posted by steenoe
Funny enough I was out of 10r's too, so I had to use two 27r's in parallel.
Steen
Maybe that's good luck. Most probably two 27's in parallel work better than a single 10 ohm resistor...
Vix
Old 14th June 2007, 08:24 AM   #262
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Damn, this look's good (and easy ) - BUT i was planning to make my future upcomming 2x F4 balanced mono-bloks. But as i see it, it is not possible to make this circuit balanced (unbal to bal converter is my only need through! as i only intend to run the signal balanced from pre ---> Poweramps).
Any suggestion's
Nelson Pass, i think you know the solution to this, what does it take for you tell hehe... ?
Thank's anyway for this great forum.
Jesper.
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 14th June 2007, 08:30 AM   #263
juma is offline juma  Germany
juma's Avatar
It really rocks the F4 to clipping...
Hi steenoe,
please help me understand how did you drive F4 to clipping with this preamp. Its power supply is 18V and it cannot be swinging more than 5-6V peak. It takes 20V peak to drive F4 to clipping.
Maybe I'm missing something?
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 14th June 2007, 08:33 AM   #264
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Jfet BOZ
Originally posted by lykkedk
................But as i see it, it is not possible to make this circuit balanced (unbal to bal converter is my only need through! as i only intend to run the signal balanced from pre ---> Poweramps).
Any suggestion's
really piece of cake, but count on few additional things:
negative supply
doubling number of jfets (hehe - that's funny) to make LTP
CCS for tail of that LTP
at least one stereo pot per channel, if not balanced stereo pot
and you're there - balanced jfet BOZ
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 14th June 2007, 08:56 AM   #265
steenoe is offline steenoe  Denmark
steenoe's Avatar
Originally posted by juma
Hi steenoe,
You are probably right. It was more likely the speakers that were tortured. In any case the J-fet BoZ can play more than loud enough with the F4. The speakers are Abby-clones with Fostex FE166's.
Jesper, take a look at the Pumpkin-mans latest creation also It should have gain and voltage swing enough for the F4. Very promising......
Steen
The Pumpkin
Lookie lookie, whats my dog doin' over there???
Poor confused thing, what happend back there?? Fart or something ?
Ratata
Old 14th June 2007, 09:14 AM   #266
ROVSING is offline ROVSING  Denmark
ROVSING's Avatar
OOH there you are Lucky - couldn't find you
Frandsen
Old 14th June 2007, 09:28 AM   #267
Magura is offline Magura  Denmark
Magura's Avatar
OK Bjarne....det var dråben!
Go build something
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 14th June 2007, 10:27 AM   #268
massimo is offline massimo  Italy
Excactly, those eyes are hypnotizing
Steen
We can hide them, if you wish (Choky's eyes, I mean)
Old 14th June 2007, 11:57 AM   #269
ROVSING's Avatar
Go build something
Magura
Yes your probably right, might make this preamp to get something finished should be possible - i think i'll make it in 1 hour just to beat "Lucky" Steenoe
Frandsen
Old 14th June 2007, 12:04 PM   #270
Magura's Avatar
If you do the footwork, and go buy two cordless powerdrills, you can make one in like 30 minutes
The reason to buy two is that you use one charger for actually charging the batteries (you can get el-cheapo chordless drills sporting 18V), and one for building the amp in. The all you need to do is to swap the batteries from the charger to the preamp (which has a socket for the batteri since it's the box from the second charger), and off you go
Magura
Jfet BOZHide this!Advertise here!
JFet BOZ Tyimo Pass Labs 14 30th April 2006 03:18 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
How to use Jfet? lumanauw Pass Labs 5 7th April 2005 03:12 AM
