Jfet BOZ
Jfet BOZ
Old 13th June 2007, 05:54 PM   #221
steenoe is offline steenoe  Denmark
steenoe's Avatar
Originally posted by mpmarino
...will the commercial version come with a roll of battery holder?
Steen, Would you say that this compares favorably with others - the X-Bosoz in particular. I know it is still early... but it took you long enuff to get one together
edit:
--or look for discounted/obsolete/new cordless drill packs at the home center
Yeah, I know that I was slow..He-he Sometimes a man needs a break.... Not that I did.. but.... confusing enough?? Figure it out yourself...He-he again. Here is the main reason for being slow lately: Greek Grillmeister makes even ZM look small...He-he
The sound of the J-fet-BoZ is just great. If you doesnt need balanced in/out look no further, if you are into the low count components category. Further impressions to come along!
Steen
Old 13th June 2007, 05:59 PM   #222
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Jfet BOZ
Originally posted by steenoe
...................If you doesnt need balanced in/out look no further, if you are into the low count components category. Further impressions to come along!
Steen
yeah.........investing in two additional jfets ,four more resistors and one more stereo pot - to have bal in -out (with condition that output load must be highish) will break a bank..............
that's for this picture!!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th June 2007, 06:01 PM   #223
twitchie is offline twitchie  Canada
now all is back to normal in the world again, congratulations Steenoe!
I am still having problems with my testing (still getting alot of distortion from external dac as source - running from laptop headphone output is nice and clear, probably due to the puny mV output from the computer jack). I'm also trying to figure out why I am no longer getting any attenuation from my (input) pot - I've tried 20K and 10K, but no luck
I've also moved off the gainclone for testing to F4, so after hearing Steenoe's comment, I'm even more anxious to get this working ... wish me luck
Stephen
Old 13th June 2007, 06:04 PM   #224
steenoe's Avatar
I knew I could tease you
Steen
Old 13th June 2007, 06:06 PM   #225
analog_sa is online now analog_sa  Europe
analog_sa's Avatar
I find this one of the most surprising threads for a while.
The circuit is an exact replica of my beloved MC stepup from about 10 years ago. At that time i also tried the Pacific riaa (ok, it lacks source resistors) but the output distortion, although pleasing was a bit too much to swallow.
Now, it's sudddenly capable of producing an output of many volts with no distortion at all.
Btw, using batteries is cheating.
Old 13th June 2007, 06:08 PM   #226
steenoe's Avatar
Twitchie: Draw up a schematic of how you connected things and post it I am quite sure that you will get the thing to work!! Mine works, so will yours!
Steen
Old 13th June 2007, 06:11 PM   #227
Zen Mod's Avatar
Jfet BOZ
Joelist?
Thorsten?
"Hi there,
>You had spoke about building this preamp. Do you have a schematic available
>for it? If so can you please send it if possible.
Here is what I have. All ASCII I'm afraid....
l'Audiophile MC Pre-Pre
Folks, with just few resistors, one JFET, one output cap you can build a
step-up device.
12 Volts regulated or accumulator buffered supply
2k2
|---------0.47uF-----out------------>
(drain) |
---in---------(gate)JFET 100k
| (source) |
100R | |
| 47R |
-ground--------------------------------------------------
The basic topology is that of the second step-up amplifier by "Maison de
L'Audiophile" of Paris/France.
The first 100R is the cartridge load, which must be adapted for the
cartridge you use. Using a paralleled 1nF cap also makes the circuit immune
against RF noise. The 47R resistor in the source is not necessary, if the
JFET has an IDSS(on) of 2mAmps or less.
As the signals are very sensitive, the voltage must be very clean, a 100 000
uF electrolytic cap for blocking power supply noise, computer grade
favourably, is advisable. Suitable JFETS are 2SK170, 2SK240 (double JFET),
2SK97 (double JFET), sorry only these japanese types are suitable, the
European BC264 and BF254 and so on do not work here (I tried !).
All resistors must be big metall resistors, e.g. Beyschlag 1Watt, or
tantalum resistors. No carbon resistors allowed here, tubes addicts.
The output cap is preferably polystyrene or polypropylene or paper-in-oil,
as you like it, as they are different in sonic balance.
Pacific RIAA Pre - 24V Version
o-----------------------------------o------------+24V
R2 R6
| D---o---C7---o
D---o---C1--R3--o--------o------o---G OUT
o---o---G | | | S---o o
IN | S---o R4 | R5 | |
o | | | | | | |
| | | o--o--o o--o--o | | |
| R1 | | | | | | | | |
| | | C2 C3 C4 C5 C6 | | |
o---o-------o--------o--o--o--o-----o---o-------o--------o--- 0V
R1 = 100k C1 = 0.47 micro
R2 = 2.4k C2 = 15 nano (ideal C2 + C+ +C4 = 99.3 nF)
R3 = 27k C3 = 15 nano well my copy says 100nF
R4 = 3k C4 = 68 nano
R5 = 100k C5 = 22 nano here its 30nF total
R6 = 2.4k C6 = 6.8 nano
C7 = 2.2 micro
We build the Pre using both the Fet Pre Pre and the Pacific. PSU is 3 X PP3
NIMH Recharables. The Pre Pre get's it's PSU via a dropper resistor and a
2,200uF Decoupling Cap (Black Gate or similar) so that 12V are supplied to
the Pre-Pre.
Later Thorsten
__________________________________________________ ____
formating is probably schmucked so- there is txt file
Old 13th June 2007, 06:13 PM   #228
Zen Mod's Avatar
Jfet BOZ
me again........(surprise?)
here is picture too,but just riaa
Old 13th June 2007, 06:18 PM   #229
steenoe's Avatar
I have no idea why you find this surprising???? Please elaborate on that. I was surprised by the sound of a simple circuit like that, but I dont think that is what you are aiming at?? What is your (ahem) aim??
Steen
Old 13th June 2007, 06:45 PM   #230
Manu is offline Manu  Europe
Manu's Avatar
Yes, what is the problem? It is a good thread, and a funny one.
And we don't say anything but the through.
manu
Jfet BOZHide this!Advertise here!
JFet BOZ Tyimo Pass Labs 14 30th April 2006 03:18 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
How to use Jfet? lumanauw Pass Labs 5 7th April 2005 03:12 AM
