Jfet BOZ - Page 2 - diyAudio
Old 6th June 2007, 05:48 AM   #11
mpmarino's Avatar
Hi Twitchie,
I look forward to your completion and impressions. I'm sure I won't get to it for quite some time. Amongst the majority of the company on DIYA I'm a hopeless newb but I think you may want to make room on the board for 10uf film caps. I'm thinking that with so few parts - selection may be more important.
Please free to tell me I'm wrong and I'll happily crawl back into my hole
Crazy Yankee.
Old 6th June 2007, 07:34 AM   #12
Manu is offline Manu  Europe
Manu's Avatar
The 170' are BL I suppose?
Manu
Old 6th June 2007, 07:50 AM   #13
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally posted by Babowana
You just got a great gift from Papa. Congratulations!
I already got Babo Zen that was much bigger than a small gift.
I wonder what Choky would get . . . ^^.
Papa already promised to me one X1000 case ,complete with hsinks
( that dreky box will be probably good enough for my next phono preamp), randomly throttle filled with small/medium/big jfet/mosfet goodies ;
he sez-because weight is slightly under 100 killos ,he will pay for shipping.......there is no need that I worry about trivia like this ........
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 6th June 2007, 09:01 AM   #14
Vix is offline Vix  Yugoslavia
Vix's Avatar
Default Re: Pass 2SK170 BOZ
Originally posted by lineup
shouldnt those resistor values be adjusted a little bit?
I mean the Drain resistor, 2k2 and Source resistor, 10 Ohm.
If am not mistaken, it should be possible to increase the source resistor to get a lower gain. But I am not sure how this would affect the operating area of the Jfet.
Second, is it possible to operate this one from a higher supply voltage (60 v)? I see that 2sk170 max. voltage is 40v...
What if we increase the supply voltage to 60v, Drain and load resistors to 3,9 K and the source resistor to 33 ohms?
I know these are basic questions, but....
Diamonds are small.
Vix
Old 6th June 2007, 09:13 AM   #15
cviller is offline cviller  Canada
cviller's Avatar
Originally posted by Nelson Pass
Maybe you would like to try this first.
How did you know I needed that exact circuit for my lunch-box project???
That saves me a lot of time! Thanks!
Old 6th June 2007, 09:35 AM   #16
Formerly "jh6you". R.I.P.
Babowana's Avatar
Very good Choky . . . ^^~
Old 6th June 2007, 09:39 AM   #17
Babowana's Avatar
Default Re: Re: Pass 2SK170 BOZ
Originally posted by Vix
Diamonds are small.
Yea . . . thanks for reminding me of it ^^
Oh, I forgot that Blues also got a special F4 front end from Papa ^^
Old 6th June 2007, 09:40 AM   #18
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: my first layout
Originally posted by twitchie
I know this one is simple enough that most people will try it P2P, but I figured this would be a good lesson in Eagle for me.
Anyway, I'm going to etch this and try it out with a regulated (LM317T) psu ... wish me luck, and any recommendations or comments are welcome.
Thanks to NP (Papa) for this
It's not labelled, but input is at the top (L&R) and output is at bottom. Large middle hole is +35V and large bottom hole is GND.
Here is a PNG image of your PCB suggestion.
I wonder if not The Master had intended source resistor = 100 Ohm
... what I can estimate, using my head only,
this would render a Lineamp with a Gain of like x5 - x7.
10 Ohm here, seems too little,
when the total Drain Lood impedance is like 1000 Ohm.
Gain is set by: 1000/(source resistor) x k
....where k maybe is something like 0.5-0.8
Let's see what comments Nelson himself has to give
( next time he can spare some time for www.diyAudio.com )
before we start decide for our Final Version.
Anyway, one resistor or two are easy to exchange ..
and for these circuits, will hardly be much smoke
lineup
lineup
Old 6th June 2007, 10:26 AM   #19
Originally posted by mpmarino
Should we have a groupbuy on the perfboard ?
LOL
Old 6th June 2007, 10:56 AM   #20
lineup's Avatar
Manu
Manu
I dont know if I have 2SK170BL spice model, but I think ....
I know I have 2SK170GR spice models. They are the ones easy-to-find.
And this is the variant of 2SK170 I can easily buy in my country.
This evening I will set up Nelson's circuit in my Electronics WorkBench, EWB MultiSim.
I will post in this thread my findings:
- regarding my optimal values of drain & source resistors.
In Nelson's schematic those are:
- 2k2 coming from power supply
- 10 Ohm ... attached to ground, 0 Volt
I will also present a fourier analys: Level of 2nd 3rd 4th harmonics.
For one rudimentary No-feedback JFET circuit, like this one,
we can expect some 2nd harmonics and considerably less 3rd harmonics
lineup
APPENDIX, software used:
EWB MultiSim for FREE download:
MultiSim Download
There is also a free evaluation version from EWB website!
www.electronicsworkbench.com
But this eval. vers. has a almost no audio transistors in spice library.
JFet BOZ Tyimo Pass Labs 14 30th April 2006 04:18 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 07:50 AM
How to use Jfet? lumanauw Pass Labs 5 7th April 2005 04:12 AM
Copyright 1999-2017 diyAudio
