Jfet BOZ
Jfet BOZ
Old 23rd May 2013, 06:21 PM   #1231
Hikari1 is offline Hikari1  United States
Originally Posted by merlin2069er View Post
wow, those are big caps.
Yes, I was a bit surprised too. And they are only 8.2UF. They barely fit in the chassis I want to use.
Old 25th May 2013, 06:33 AM   #1232
Got it put together and...
It passes a signal but there's no gain...
I'll double check the schematic but something is not right. Bad jfets? They are BL grade left over from another project.
Old 25th May 2013, 12:24 PM   #1233
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Jfet BOZ Send a message via Yahoo to vdi_nenna
Any pics of the final build? A few angles, please.
I build, therefore I am.
Old 25th May 2013, 05:48 PM   #1234
Heres some pics, kind of a mess but you will get the idea.
All the RCA rounds and pot grounds are going to the copper "bus" between the caps.
Powered up, I only have .3V between D-G on the jfets. I've got 19V before the 2.2K V+ resistor and .3V after it.
Thanks for the help.
Old 25th May 2013, 08:06 PM   #1235
vdi_nenna's Avatar
Putting the volt meter across the 2.2k, Pos. meter lead on the 19v side and the Neg. lead on the drain side, what's the voltage reading? Check the value of the 2.2k with unit powered off. What's value of the Source side resistor? Check orientation of jfets as well.
Do you have spare 2sk170 jfets?
Old 25th May 2013, 09:08 PM   #1236
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Jfet BOZ
looks like you have twisted the caddock resistor wire around the jfet middle leg
soldering that could be too much heat for the jfet
besides, there is no reason to twist the wires at all
thats said, I have not been able to destroy mine
tough devices
Old 26th May 2013, 02:28 AM   #1237
I've got 19V+ across the 2.2K. The 2.2K measures 1.2K with the unit powered off. Verified the source side resistor is 10ohm.
I am suspecting the jfets.
Old 26th May 2013, 05:37 AM   #1238
Oh man. I had made a stupid mistake.
I had just bought a thrift store DMM before assembling the jfet boz. I didnt realize the leads were plugged in backwards. I was delivering -19V NEGATIVE through the power supply. Stupid.
Well, I realized this, swapped the battery leads and...IT WORKS.
But it doesn't sound so good. It has lots of gain but it sounds a bit distorted and the soundstage is small. I will investigate further...
Old 26th May 2013, 06:46 PM   #1239
vdi_nenna's Avatar
That's ok. Things happen.
Are the batts fresh?
Old 26th May 2013, 07:35 PM   #1240
Jfet BOZ
I think original curcuit values were intended for much higher voltage
on a battery it might be under biased
but yeah, low battery sounds pretty bad too
at least you have a signal now
good step forward
Jfet BOZHide this!Advertise here!
JFet BOZ Tyimo Pass Labs 14 30th April 2006 03:18 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
How to use Jfet? lumanauw Pass Labs 5 7th April 2005 03:12 AM
