Old 10th February 2013, 11:12 PM   #1221
tinitus is offline tinitus  Europe
thanks !
at first it had so much overdrive, and it distorted way too easy
now it does not sound distorted at all
it can still be pushed into overdrive, but only very very mild...and really sweet
but I still have a stereo unity gain buffer with attenuation between this and my big solid state 150watt hifi poweramp, or else it gets too much
but I'm very happy with the 'small stuff' I have learned from this
a break, and then on to the next project
cheers
Old 24th February 2013, 12:55 PM   #1222
Tyimo is offline Tyimo  Hungary
Hi!
Is it possible to use this JBOZ as I/V converter for AD1865DAC?
If I remember well the gain of this amp: x16, +24dB?
Greets:
Tyimo
Old 23rd May 2013, 05:10 AM   #1223
Hikari1 is offline Hikari1  United States
I am attempting to point to point a jfet boz.
I forgot to order the 475 ohm resistors on the output. Can a higher or lower value be used here? I have some 1K's and 910ohms I could parrallel up I guess for about 450 ohms.
Thanks.
Old 23rd May 2013, 05:20 AM   #1224
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Thanks.
Parallel a couple of 910s.
I build, therefore I am.
Old 23rd May 2013, 06:10 AM   #1225
I'll give that a shot. Making progress so far.
Old 23rd May 2013, 08:43 AM   #1226
mhouston's Avatar
Thanks.
Mate just use 1k or anything close. The preamp probably loads into a minimum of a 10k load. 450ohms or 1k it really doesn't matter.
Old 23rd May 2013, 08:52 AM   #1227
mine are 560ohm
Old 23rd May 2013, 05:18 PM   #1228
Almost done. I doubled up two 1K's for the output.
I plan on using batteries like the diagram attached. Probably wont use any PS caps or maybe 1,000 UF or so.
Question: Should I just run the Pot/RCA grounds to the copper ground "buss" in the middle of the caps?
Old 23rd May 2013, 05:47 PM   #1229
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
use anything between 22R and 1K
it's there as idiotproof level increasing part
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 23rd May 2013, 06:04 PM   #1230
merlin2069er's Avatar
Send a message via MSN to merlin2069er
wow, those are big caps.
JFet BOZ Tyimo Pass Labs 14 30th April 2006 03:18 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
How to use Jfet? lumanauw Pass Labs 5 7th April 2005 03:12 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
