Jfet BOZ
Jfet BOZ
Old 9th February 2013, 01:29 PM   #1211
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Jfet BOZ
Originally Posted by robertor View Post
1 step and already sounds, second step and it sounds too strong.
to prevent this, or use an 20k input pot or what?
then you don't need the gain, but could do with a unity gain buffer, like the B1
but you can try with a simple voltage devider instead of the pot
its basicly the same just with a fixed setting
or you could use switch with a few optional settings
if you look at your pot(schematic), you will notice that its basicly just two resistors changing value
when the series impedance goes up, impedance to ground goes down
and your load impedance and pot value is the sum of both
so I will suggest you replace the pot with a 3 or 4position switch mounted with fixed resistor attenuation
Old 9th February 2013, 03:02 PM   #1212
robertor is offline robertor  Hungary
robertor's Avatar
Jfet BOZ
Originally Posted by tinitus View Post
try mount resistor from wiper to ground
i don't know what is wiper.
rob
Old 9th February 2013, 03:02 PM   #1213
Floric is offline Floric  Europe
maybe close, but maybe you forgot the 330ohm in series to ground ?
No, from the wiper to ground there are two 330R in series, 660R in total. Just wanted to avoid a bad surprise on your side... (I already had surprises like that)
If the gain is too high for your needs, I would have added a resistor of some kR before the 10k pot.
Best regards
Flo
Old 9th February 2013, 06:22 PM   #1214
Jfet BOZ
you are right...thanks
but so far its no problem
basicly the red marked resistors are only there for the following balance pot
or else it doesnt work enough
the balance pot is the real wrong part of this
should just have been two attenuators instead...but this was an experiment to make simple balance control, and not to be copied directly
next one will be better
Old 9th February 2013, 06:26 PM   #1215
Jfet BOZ
... I would have added a resistor of some kR before the 10k pot.
forgot to try that too will see what it does, thanks
Old 9th February 2013, 06:28 PM   #1216
AudioSan is offline AudioSan  Norway
wiper is the center pin of the pot.
Old 9th February 2013, 06:31 PM   #1217
Jfet BOZ
the wiper is the variable pin from your pot, the one marked with an arrow in schematic
but if its your PC, I wouldn't mess with that
forget what I said about resistor on pot
your real problem is way too much gain
Old 9th February 2013, 06:40 PM   #1218
robertor's Avatar
Jfet BOZ
ok, thanks tinitus, thanks guys.
I tried this Boz, which I think is great sounding, but the B1 will jump in my audio set up.
but......stay tuned.
rob
Old 10th February 2013, 05:47 PM   #1219
Jfet BOZ
.... if you turn the 10k pot up for full volume, the JBOZ in the first stage will only see 660 R to ground.
This is a little low, I think it will give you "real Distortion".
looks like this now
replaced the 330ohm to ground with a 680ohm
tried other resistor combinations
also the 'ordinary', and with bigger resistors
all resulted in more distortion
also looked at where I could place a cap
works exstremely well like this
not exactly sure what it does, other than lowering impedance with rising frequency
but the result is that the balancing pot is much more effective now, and adjustments very audible, and easy
turning balance pot change the sound from dry to airy, and thats about it
well, guess I should say, one output is driving the bottom end, and other channel the top section
and from now on it belongs in my bass guitar preamp thread
Old 10th February 2013, 10:58 PM   #1220
looks like this now
O.k. then you are going in the direction of 1k for full volume. Not much for the JBOZ but in every case better than 660R.
Did not realite that your schematic was built for your bass guitar preamp. For stuff like this, anything goes. As long as it does not damage the gear. For music playback, I think we should avoid distortion to a decent degree.
I used to play the bass guitar too, so I know, that you sometimes need a lot of "good" distortion
Have fun with it!
Jfet BOZHide this!Advertise here!
JFet BOZ Tyimo Pass Labs 14 30th April 2006 03:18 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
How to use Jfet? lumanauw Pass Labs 5 7th April 2005 03:12 AM
