Jfet BOZ
Jfet BOZ
Old 8th February 2013, 11:22 AM   #1201
robertor is offline robertor  Hungary
robertor's Avatar
Jfet BOZ
arranged the grounding, finish the hum.
rob vs Boz 1-0 !
rob
Old 8th February 2013, 12:03 PM   #1202
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Jfet BOZ
rob vs Boz 1-0 !
mine works very well too although a different 2-stage mono version with 2-channel split, for my bass guitar
Old 9th February 2013, 06:13 AM   #1203
robertor's Avatar
Jfet BOZ
power supply:
rob vs BoZ 2 - 0
rob
Old 9th February 2013, 07:18 AM   #1204
robertor's Avatar
Jfet BOZ
the big question:
waiting to build a DAC which is based on the TDA1541, the Boz will be connected to the output of the PC.
I would not use the potentiometer as the volume would be controlled by the PC.
I must to replace the potentiometer 20k of Boz with some component (resistor, capacitor, resistor and capacitor)?
the question comes for not using two potentiometers.
unnecessary in this case.
thanx
rob
Old 9th February 2013, 07:27 AM   #1205
Jfet BOZ
no, you have 1k in series, and 1M to ground
unless you have too high output from DAC, and is overdriving your jfet Boz
Old 9th February 2013, 11:53 AM   #1206
robertor's Avatar
Jfet BOZ
THANKS for answer.
The PC output "saturate" the Boz.
In fact I do not have a large volume control.
1 step and already sounds, second step and it sounds too strong.
to prevent this, or use an 20k input pot or what?
rob
Old 9th February 2013, 11:56 AM   #1207
Jfet BOZ
try mount resistor from wiper to ground
and you can mount a resistor in series with signal, on pot input
what is your pot impedance ?
Old 9th February 2013, 12:13 PM   #1208
Floric is offline Floric  Europe
Sorry, might be a fault thought from my side, but if you turn the 10k pot up for full volume, the JBOZ in the first stage will only see 660 R to ground. This is a little low, I think it will give you "real Distortion".
My intention is always to try that the stuff I built works with every setting of the knobs - I often tend forget the boundary conditions by the time...
Just my 2ct.
Best regards
Flo
Old 9th February 2013, 12:58 PM   #1209
robertor's Avatar
Jfet BOZ
@tinitus: i don't know the impedance of the pot of the PC.
sorry
rob
Old 9th February 2013, 01:21 PM   #1210
Jfet BOZ
Originally Posted by Floric View Post
... first stage will only see 660 R to ground.
maybe close, but maybe you forgot the 330ohm in series to ground ?
yes, there is a little distortion at full volume
but the gain so excessive I have to use a buffer with further attenuation
anyway, I have tried other resistor combination on the pot
all sound differnt
this one is so far the best
also because this special resistor 'curcuit' seems to interact better with the following balance pot, making it work more
but no, its far from ideal, and just a proto to see how it works
most are random components I found
but it works, and I havent been able to kill it yet
tough little amp
Jfet BOZHide this!Advertise here!
JFet BOZ Tyimo Pass Labs 14 30th April 2006 03:18 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
How to use Jfet? lumanauw Pass Labs 5 7th April 2005 03:12 AM
