Jfet BOZ
Jfet BOZ
Old 30th September 2012, 08:07 AM   #1161
R.I.P.
Would lsk170c be a good substitute?
regards Andrew T.
Old 1st October 2012, 06:43 PM   #1162
robertor is offline robertor  Hungary
robertor's Avatar
Jfet BOZ
Hello everyone and sorry for my bad English.
some time ago I bought the "JFET Boz" of JimsAudio that I would like to build. i have a transformer with double secondary (0-15V and 0-24v).
the 0-15v does go already the diamond buffer headamp of Sijosae.
now the question: the JFET Boz of JimsAudio can work with a voltage of 24V AC , if I am not mistaken, after the rectification bridge and filter capacitors will be 32-33v DC ?
Thanks in advance for any help.
rob
rob
Old 10th October 2012, 07:43 PM   #1163
Abx74 is offline Abx74  France
It depends of the bridge rectifier loss and your resistance value in your CRC PSU filter, but yes about 32V
Old 12th October 2012, 06:55 AM   #1164
Tolu is offline Tolu  Germany
Tolu's Avatar
Default Jims Audio PCB
I have got the PCB from Jims Audio, too. I just want to buy the necessary parts. In the part list of Jim is D6 not required. Therefore I just need a piece of wire, or?
On the photo at the website is just one Zener diode and not 4 as required in the part list or at the PCB! Has anyone assembled this PCB and can help?
Has anyone experience with this PCB and how is the quality of the power supply?
Old 12th October 2012, 11:35 AM   #1165
ramallo is offline ramallo  Europe
ramallo's Avatar
Jfet BOZ
No, nothing on D6
In this photos I have replaced the diodes by a TL431 circuit (For fine tuning the V supply)
Happiness is a warm soldering iron
Old 12th October 2012, 11:38 AM   #1166
ramallo's Avatar
Jfet BOZ
rob
Depends of the IDSS of the K170, with high V types you can use 30V of supply
Old 12th October 2012, 12:03 PM   #1167
Tolu's Avatar
Hio Ramallo,
normally, I will need the 4 Zener diodes!
I think it's a little bit like gambling if the 16V fit to the Idss of the 2SK170.
Would be nice to have a Idss -> V - table to see what's the best voltage for the specific jfet if you have no oscilloscope.
Old 12th October 2012, 12:17 PM   #1168
ramallo's Avatar
Jfet BOZ
Hio Ramallo,
Look Jfet BOZ
Old 12th October 2012, 12:34 PM   #1169
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Jfet BOZ
probably because its been copied from Nelson's first schematic showing 35V
whatever, here is my version
Old 12th October 2012, 01:38 PM   #1170
Tolu's Avatar
Originally Posted by ramallo View Post
what a memory!
Nice idea with the little TL431 PCB! Does it work as you planned?
I'm considering to use 2 lead batteries for a phono pre so there would be enough power to drive the jfet boz and a DAC.
@tinitus: the chinese are copying anything. Not innovative but cheap.
Jfet BOZHide this!Advertise here!
JFet BOZ Tyimo Pass Labs 14 30th April 2006 03:18 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
How to use Jfet? lumanauw Pass Labs 5 7th April 2005 03:12 AM
