#1131 |
not exactly on par
B1 and JBOZ are just having context and goals , so final quality is different
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#1132 |
@tinitus: After building both the B1 and quite a number of BoZ the B1 sounds better but I need gain to for my low gain tube power amps. So BoZ works for me. But BoZ (or my BoZSE) is an excellent sounding dead simple jFet preamp.
#1133 |
I increased the drain res to 3K2ohm
source res is still 15ohm now I measure 16V over the drain and measure over source res, it circles around -1mV and +1mV totally different values now it sounds like fresh running water
#1134 |
With my BoZSE and a 24V supply I can get 17V swings with no clipping into 10K.
#1135 |
turned into a very nice distortion machine
![]() back to 1K5 drain res, and 15ohm source ![]() shows the input is very easy to overdrive I have 850K to ground, and cant go any lower 1M is probably 'safer' maybe gate/series res could be increased
#1136 |
related power supply
well, I never tried those little 1ohm series resistors, and thought this might be a good moment for it and I can only say ouch this happened yesterday, before any of my posts here I didnt notice at first, but the downwards slide had begun, hunting other 'sound improving' adjustments which probably gave me a clown award ![]() but also learned something very interesting fortunately that sweet sound I had experienced earlier came back instantly when I removed the series resistance it may lower noise, and some claim quite a lot but to my ears it definately kills this little curcuit, and what it does best for me personally, series resistors are out, sorry |
#1137 |
#1138 |
@Juma: Yes peak to peak.
#1139 |
I have seen a se output buffer with jfet and a bjt inserted in the drain, and connected to source(out)
dont know what its called thought it might be worth a try since i found some older BC547 |
#1140 |
searching, but not much to find, other than it looks like a ccs turned backwards
and bjt appears to be biased through the jfet drain resistor
| JFet BOZ | Tyimo | Pass Labs | 14 | 30th April 2006 03:18 PM |
| Can I replace BF245C JFET with J201 JFET? | bigmike216 | Parts | 2 | 7th December 2005 06:50 AM |
| How to use Jfet? | lumanauw | Pass Labs | 5 | 7th April 2005 03:12 AM |
