Jfet BOZ - Page 113 - diyAudio
Old 17th January 2012, 06:20 AM   #1121
juma is offline juma  Germany
juma's Avatar
Originally Posted by audionut View Post
... so this pre amp is not suitable where you need to swing voltage up to 2v into a lowish gain amplifier ??
If you don't mind 5% THD at 2V output, you'll be fine.
Originally Posted by mhouston View Post
My BoZ and BoZSE produce 17V p2p of swing before any degeneration of sine wave. I run mine on 27V. I'm using the BL series of jFets.
I suppose you mean JBOZ. If that's so, 17V p2p is 6V RMS. JBOZ puts out 2V with 5% THD at 16V PS. I don't know how much THD you'll get with 27V PS at 6V RMS output, but if you like the sound, everything is fine.
If you mean the old BOZ (with MOSFET) that's another pair of socks...
Old 24th May 2012, 05:39 PM   #1122
TB is offline TB  United States
Hello,
Is it possible to use 1.2k input resistor instead of 1k and 470 Ohm output resistor instead of 475 one without ill efects?
I want to build original pre based on schematic posted by Mr. Pass in post #2 with 16 Volts PSU.
Old 24th May 2012, 06:15 PM   #1123
Absolutely... And I'm in Nova too, why don't I know you ;-)
Roscoe
Old 24th May 2012, 07:52 PM   #1124
Hello Roscoe,
Thanks for the answer.
Where are you located in Nova?
Old 24th May 2012, 09:23 PM   #1125
Out near Warrenton. We have a DC area DIY group that gets together about monthly. Unfortunately most of them are in MD, we could use some more in VA ;-) We're going to have two rooms at the Capitol Audio Fest this year . See HiFi Heroin for commentary on our room from last year.
Roscoe
Old 29th May 2012, 03:18 PM   #1126
Hello Roscoe,
I am in Arlington. Warrenton is nice and higher altitude is better for HiFi sound
Old 24th August 2012, 07:17 PM   #1127
tfender is offline tfender  Thailand
Very Good
Old 22nd September 2012, 08:42 PM   #1128
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
hey, I can report that I have got a simple jfet boz test amp up and running for my bass guitar
+17.5V before Drain resistor
7.1V measured over it (1250ohm)
-82mV measured over source resistor (15ohm)
carbon film resistors
signal resistors are metal film
needs volume att and buffer
Old 22nd September 2012, 08:50 PM   #1129
6L6 is offline 6L6  United States
6L6's Avatar
How are you using it? To put the instrument into your stereo? As a gain pedal? Driving a amp? (Combo or head) ?
Just curious.
Old 22nd September 2012, 08:57 PM   #1130
only one jfet so far
so its just mono, but split to 2 outputs/RCA going to a 2 channel stereo preamp
but hope to have more of them later
dont know if this is of any use to you guys
but for my particular project its clear to me that every gain stage must have its own attenuator to control the gain, and as a result, additional buffer
so to those who have a B1, but desperately needs the additional gain, just put the simple jfet in front of the B1
could be there will be minor grounding issues to deal with
or could just a small ad-on with its own battery supply( I think Nelson also suggested battery)
JFet BOZ Tyimo Pass Labs 14 30th April 2006 03:18 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
How to use Jfet? lumanauw Pass Labs 5 7th April 2005 03:12 AM
Copyright 1999-2017 diyAudio
