Old 24th August 2011, 03:54 PM   #1041
That result of better sound by fitting a pre-amp tells me that the source was incapable of driving the load you attached to it.
It is the Source you should be trying to sort out.
Old 12th September 2011, 01:29 AM   #1042
timbarnes's Avatar
Default Feeding my new F4
Having just finished my F4, I've been thinking about a suitable gain stage for it, and I have built two.
The first was a simple 5534 op-amp preamp: it seemed to work fine, but I wanted to try something a bit more exotic, so I found the JFET BOZ.
A quick lash-up on a matrix board, stuck in an L-shaped support, powered by a couple of 9 volt batteries.
Sounding good.
No tuning yet: I'm planning to try 27V to see if there's much of a difference when I get a chance.
The gain stage is connected to an old First Sound passive preamp, so I have too many cables, but it seems to work. I omitted the gain control from the JFET BOZ therefore.
tim
Townshend Rock III w/ DC motor, EAR 834P, Naim CD5i, Voyage MPD, ODAC, Audio Research LS3, MiniDSP, Pass F4, Parham Pi Sevens
5532 Preamp, JBOZ, DIY Silver cables, Open Baffles, DIY subwoofer, First Sound Passive, Pass BA-3, GainClone, o2 Headphone Amp
Old 12th September 2011, 01:49 AM   #1043
ramallo is offline ramallo  Europe
ramallo's Avatar
Send a message via Skype™ to ramallo
Sounding good.
tim
You can try with a distortion analyzer for get the adequate voltage supply for your jets.
Happiness is a warm soldering iron
Old 12th September 2011, 01:54 AM   #1044
The one and only
Nelson Pass's Avatar
Next you will need to try the BA-3.
Old 12th September 2011, 02:03 AM   #1045
ramallo's Avatar
Old 12th September 2011, 02:36 AM   #1046
timbarnes's Avatar
I'll be at BA looking forward to learning more. Unless you'd like me to get started early...
Old 12th September 2011, 02:37 AM   #1047
timbarnes's Avatar
Ain't got one. Just a multimeter. But it is sounding good.
Old 12th September 2011, 03:08 AM   #1048
mhouston's Avatar
You'll be happy with BoZ. I've built four, all slightly different and a B1. I felt the B1 had a better mid-range but I needed more gain so BoZ was the answer.
I may have posted this before but here is my BoZ on a cap (BoZoaC). Shortest signal path on the planet.
Old 12th September 2011, 12:55 PM   #1049
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Somewhere in this thread, Mr Pass said 16v is the sweet spot. So you are close right now.
Or, you can try this suggestion.
Source resistor value change was also discussed. I think it changed from 10 to 22 Ohms, but check to be sure.
See post #691
Jfet BOZ
I build, therefore I am.
Old 12th September 2011, 01:13 PM   #1050
ramallo's Avatar
Without a distortion analyzer this post will be a good start point for you
JFet BOZ Tyimo Pass Labs 14 30th April 2006 03:18 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
How to use Jfet? lumanauw Pass Labs 5 7th April 2005 03:12 AM
Copyright ©1999-2013 diyAudio
