Old 24th January 2003, 02:34 PM   #1
Send a message via MSN to Scribble
Exclamation Variac?
Ive read that it is essential to use a variac and slowly up the voltage the first time you run the amp and measure some points some where?
I understand the measuring part but is a variac absolutly necessary. As they are rather pricey (AU$199) i would not be willing to buy one. Is there another safe avenue i could take?
I was unshore wether this belogns here or in the electroncis forum. Moderators move at will
Thanks,
Joel
Old 24th January 2003, 02:44 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
If you have done everything right there is no need for a variac but it's nice to it just in case. The use of a variac is just protection against blue smoke but one another trick is to fuse down the amp. Use a little bit smaller fuses.
/Per-Anders (my first name) or P-A as my friends call me
Old 24th January 2003, 02:47 PM   #3
Ive read bout that too. Thast where you start off with low value fuses then go up a little untill they dont blow any more on normal operation?
Please correct me if i wrong as im here to learn
Joel
Old 24th January 2003, 02:56 PM   #4
tiroth is offline tiroth  United States
Put a light bulb in series with your transformer primary. Check www.sound.au.com or in the forum logs for more info about this.
Old 24th January 2003, 02:58 PM   #5
peranders's Avatar
Try to calculate how much the amp will draw with a low signal (output power). Don't use too small fuses.
Old 24th January 2003, 04:49 PM   #6
The one and only
Nelson Pass's Avatar
Anybody who is serious about this will want to buy
wire cutters, soldering iron, multimeter, scope,
and a Variac (tm) in that order. An oscillator you can
build once you have a scope.
Old 27th January 2003, 02:15 PM   #7
Sandy H.'s Avatar
Default I was close. . .
I have the cutters, iron, multi-meter, scope and decided to build a +/-25V adjustable lab supply (Rod Elliot project). Guess I should have gone with the variac. . .
A quick question, though: I can use the adjustable supply to re-form older caps? It seems that if I were to throw in a 10k resistor and connect my PS caps one at a time to the supply, I could bring the voltage up from 1-25V and drain back down with a resistor. Is that the proper technique?
Considering the above, I plan on being quite cautious with the caps, as is always recommended.
Any other suggestions for re-forming or testing surplus caps?
S.
Old 26th July 2004, 10:32 PM   #8
Frazzled's Avatar
Check, check, check, check and check!
Anything worth trying is worth failing at once or twice.
Old 28th July 2004, 07:58 AM   #9
D3 is offline D3  England
D3's Avatar
Default Testing 1-2-3..phuttttt
Frazz is right.................on the last project I did...it took me ages to check things out........only to be caught out with a tiny solder...... track....(about width of a human hair).......this gave me a real fright..........when a mini cloud of smoke rapidly appeared.
Fortunately no damage ensued......but this was a low power preamp.........I think the china syndrome is far more likely with a powerfull poweramp........and big powersupplies......any body fancy a bacon sandwich....
So .... I've invested in a variac........you just can't be too carefull.
D3 Bolton uk
Old 28th July 2004, 12:37 PM   #10
Cr3ator is offline Cr3ator  Netherlands
Default Ebay
There are plenty of Variacs for sale on Ebay or other websites where you can buy second hand stuff. You can find them from $2 - $600... good luck!
ErikH
DIY Variac Tyimo Solid State 4 6th October 2007 11:18 AM
FS 10A variac woody Swap Meet 8 16th May 2007 04:38 AM
Variac ben goh Solid State 21 12th March 2007 06:42 PM
Using a variac. anders.a Parts 3 4th April 2006 07:12 PM
Page generated in 0.10019 seconds (75.95% PHP - 24.05% MySQL) with 10 queries
