When powering up my Aleph-x at about 5V (normal is 24 V) two electrolytes are getting warmer then six of the rest. About 29 C instead of 24 C. Is this something to worry about?
#2 |
are this two in same position in circuit as rest of them?
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
Yes, maybe.
If the ambient temperature is 24°, and the rail voltage is only 5V, I would presume something is wrong. Is the amp newly build or not? /Hugo |
#4 |
Zen Mod
Yes they are. Netlist Yes it is. This is the first test. Slowly, slowly I’m raising the voltage.
#5 |
Don't raise the voltage.
5V is plenty and don't leave it on too long if the caps get warm. Measure if your polarity is correct; confirm you got a positive voltage on the positive side of the cap and negative on the negative side. That would of course be DC. Tell us if you measure AC voltage over the caps as well and how much. In any case: don't raise that voltage for now. /Hugo |
#6 |
Netlist
That will I certainly do, tomorrow. Powering it up again. Now it has disappeared. Strange. I’ll be back tomorrow with further reports. Netlist Do you measure this with or without connecting it to the power mains? (Maybe a stupid question but I'm asking it anyway to be sure). |
#7 |
When you told us about the 5V, I assume there was mains voltage true a variac. I also assume the 5V was the rail voltage you measured somewhere after the rectifier. It is obviuos that you can not measure voltage without applying the mains.
Try to be specific as to what and where you measure voltages. Can you post a schematic of the power supply you used? /Hugo |
#8 |
Netlist
Yes I’m using a variac. 5V was measured after the capacitors. between + and ground and - and ground. Using two multimeters. Here’s the schematic: http://www.kk-pcb.com/power-x.html |
#9 |
Well, keep the multimeters in place, slowly rise the voltage and keep an eye on the caps for heat.
It would be best to disconnect the power supply from the amp until you are sure both + and - voltages are fine. /Hugo |
#10 |
Netlist
Using the Vac scale on the multimeter I couldn’t find any AC. But another thing happens. When turning down the variac after measuring voltage. The voltage quickly goes down to 0V. I don't think that is ok. |
| SI T-amp warm-up? | irss | Class D | 3 | 8th April 2005 11:40 PM |
| My amp gets warm... | Jye | Multi-Way | 6 | 21st November 2003 11:53 PM |
| Warm capacitors in power supply | peranders | Solid State | 4 | 24th September 2002 10:34 PM |
| Page generated in 0.10363 seconds (77.85% PHP - 22.15% MySQL) with 11 queries |
