Old 20th May 2007, 01:03 AM   #1
Send a message via MSN to tze-hao yen
Default hdam and aleph-p
hi
do the aleph-p need Marantz HDAM SA?
or at least to make sound like marantz?
Old 21st May 2007, 09:01 AM   #2
Stones is offline Stones  United States
Stones's Avatar
I'll have 10 pints of whatever you are drinking
Old 21st May 2007, 09:16 AM   #3
Fox is offline Fox  Netherlands
Fox's Avatar
Default Huh?
Why bother with a Pass preamp when you want a Marantz preamp?
Fox
Old 21st May 2007, 11:00 AM   #4
not hting just have an aleph and want know what will be sound like when it was addit to it
Old 21st May 2007, 01:50 PM   #5
Fox's Avatar
Wonderful. The Aleph P is very transparent, smooth and dynamic. Just like an Aleph power amp. You will have nothing left to be desired ...
Old 22nd May 2007, 03:04 PM   #6
Stefanoo's Avatar
have you build the Aleph P1.7 ?
Just thought...
if so what is the audio chain where you use it on?
Stefano
Old 22nd May 2007, 07:06 PM   #7
aleph-x, marantz sacd plyer , ar limited 3 speaker, gold point volummen controur. kinler kable ag4 and double tc8
Old 24th May 2007, 03:13 PM   #8
apassgear's Avatar
Default Re: hdam and aleph-p
Originally posted by tze-hao yen
hi
Your question is somewhat sketchy but if I interpret your intentions are to mate a Marantz CD player or amplifier with Aleph P preamp.
As far as I understand HDAM acronym on Marantz products refers to a discreet buffer added to the output audio section of CD players to lower output impedance which is certainly a good thing. And they may use this *technology* buffers in other products to do similar duties or up the input impedance say on amps.
Pass preamps are quite transparent and they should work well with Marantz gear and you will certainly enjoy the *Marantz* music through a well setup system that includes a Pass preamp, this is done every day all over the world.
There is no need to add a buffer to the output of a Pass preamp if the input impedance of the amplifier you will be using is at least 20K Ohms or higher.
Old 25th May 2007, 12:02 AM   #9
so you think it will be no need for the aleph-p to have hdam buffer is that right ?
Old 25th May 2007, 12:44 AM   #10
apassgear's Avatar
If you are using an original P 1.7 you don’t need a buffer since the output impedance will be between 0 and 800 Ohms.
Now if you are building a clone that’s a different matter all together and mainly will depend on how you implement the attenuator. Most of the clones I have seen around have not been done correctly and appear to have high output impedance. I would suggest you read the BOSOZ preamp from the Pass DIY site in order to get a gasp on this.
HDAM / Diamond Buffers Q RnR Solid State 0 21st April 2009 09:59 PM
Marantz HDAM SA BTomi Digital Source 1 1st December 2008 06:35 AM
Bypass Hdam CD 6000 aleksandar Digital Source 1 6th July 2007 10:12 AM
HDAM Bypassing poynton Digital Source 13 18th May 2007 08:22 PM
Marantz HDAM module parsecaudio Solid State 7 19th December 2006 02:00 AM
Page generated in 0.10062 seconds (75.62% PHP - 24.38% MySQL) with 10 queries
