PI-filter (or CLC vs CRC vs C) - Page 3 - diyAudio
Old 17th May 2007, 10:01 PM   #21
Magura is offline Magura  Denmark
Magura's Avatar
You can ditch the zeners and just accept that you have no voltage ref., or go down the LED ref. path.
But really for a pre-amp, there is little to gain by going much further than a run of the mill regulator like the one seen in the BOZ article. I have added a CLC to the one I have in my test setup....I found no benefit (but also no drawback besides the price of the inductor).
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 17th May 2007, 10:18 PM   #22
steenoe is offline steenoe  Denmark
steenoe's Avatar
Originally posted by Stefanoo
how can i match a big CLC with a regulated pwer supply without using zeners? ... mmm... i will read very carefully that pdf attached...seems very interesting.
Now it's just too late.....
That is not the obvious way to do it! If you want to make a CLC supply, you simply choose a trafo that fits! The option to do both a CLC and a reg. supply will be like shooting a goose after its dead allready
A CLC supply is very fast and responsive and the sound is just about the best that can be had!! If you dont like the big coils for whatever reason, make a regulated supply as suggested in my earlier reply. Strictly speaking from practical experience!!
Steen
Old 17th May 2007, 10:30 PM   #23
apassgear's Avatar
Steen
Ditto
Old 17th May 2007, 10:44 PM   #24
Cloth Ears's Avatar
Originally posted by Magura
The "roll your own" solution is not that much trouble, and hands you a very flexible solution for future projects as well.
Magura,
I'm not fussed with rolling them, it's just that finding the right wire (50m of 14 gauge) is posing a bit of a problem via the internet (and it's been raining here for a week). When it clears up I'll have to do some looking myself...
A very good example is to be found here: http://www.passdiy.com/pdf/zen-ver3.pdf Do mind, though that if you make a dual-rail from that PDF, the lower fet must be turned a 180 degrees!!
Steenoe,
I've been looking at the power supply in http://www.passdiy.com/pdf/zen-v5-hires.pdf, and it seems to be the same as the bipolar regulator in the pdf you mentioned (but with a CLC ). Which picture were you referring to, if I might ask?
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 17th May 2007, 10:54 PM   #25
Magura's Avatar
Originally posted by Cloth Ears
Magura,
Hmm, may I suggest the cheap, easy and quick solution?
Simply buy a roll og 14avg and be done with it for any foreseable future ? I'm quite sure it's cheaper than any of the other solutions, and you will have enough for making a few experiments.
Magura
Old 17th May 2007, 11:20 PM   #26
I swear you guys could make breathing difficult if you put your minds to it.
Grey
Hint: If it's inductance you want, buy a spool of wire. Hook up one end. Hook up the other end (it's tucked through a hole into the center of the spool). Poof! You're done.
Old 18th May 2007, 12:45 AM   #27
Cloth Ears's Avatar
But I've never breathed before (and some guy keeps turning me upside down and Click the image to open in full size. hitting me)!
I'm not trying to be difficult, but any solution (spools of wire, rolls of 14awg, 4 inductors off the rack) adds up to over $200 down here in Australia. My apologies if not being a spendthrift (OK, being cheap) offends...Click the image to open in full size..
Jont.
Old 18th May 2007, 08:01 AM   #28
Stefanoo's Avatar
i would like to have guys your opinion on this power supply design.
It's for the Aleph P1.7.
Since the preamplifier absorbes a constant current (correct me if i'm wrong) of about 69mA, i place the constant current source as load.
If i'm mistaken, plese correct me.
Here's the schematic
Stefano
Old 18th May 2007, 08:06 AM   #29
Stefanoo's Avatar
here a screenshoot of the regulation capability of this circuit.
I simulated it with a good resolution (5usec as maximum step size).
The rail voltage for the P1.7 is supposed to be 60V.
As you can see with this specific it's 63V.
This is because i picked out the Plitron transformer attached on the link
http://www.plitron.com/shopping/shopexd.asp?id=170
I would you use two of them for the two channels. (i still have to figure out a way to get them without paying this high shipping expences).
Here's the simulation screenshoot
Stefano
Old 18th May 2007, 08:20 AM   #30
Stefanoo's Avatar
this is a zoom of the initial part.
There is a negative peak.
Could it contituite a problem? how is it possible to eliminate, in case?
Here's the screenshoot.
Thanks in advance for your kind advice guys.
Best.
Stefano
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
Just one big filter cap or more smaller filter caps ... beppe61 Power Supplies 2 18th July 2006 05:46 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
chassis-mounted filter or IEC plug filter jarthel Solid State 7 11th March 2002 10:17 AM
Copyright ©1999-2017 diyAudio
