Old 21st January 2003, 07:08 PM   #1
Default capasitor
Ok, I need information!
Today, I buy 8 capasitor SANGAMD type CDM 6700uF 75VDC
The probleme is: When I put 9 vol in, it diseaper in a second! Even if a put 4 of them in parallel.
It a compare to only one 15600 uF 50VDC who can keep the 9 volt during minute ou hours...
It is possible that this i not electronytic capasitor? Or they are dead!
Do you advise to put this capasitor in the power supply of my Zen V4 ???
What is the problem???
Old 21st January 2003, 07:32 PM   #2
Send a message via ICQ to ThingyNess
It's likely that the capacitors are very old, and their leakage currents are very high.
Leave a voltage between 40 and 70VDC connected to them in series with a 1k, 10W (or any value around there) resistor to limit the current they draw. Leave them like this for a few hours. Hopefully they'll slowly get better and reduce their leakage current to an acceptable (but still over-spec) value.
Old 21st January 2003, 07:38 PM   #3
Is is very boring... I buy it and they are old....
I will return it at the store... thank you very much for the information!!!
Old 31st January 2003, 02:27 AM   #4
I try to get some good capasitor put I am unable to find! Somebody know where a can buy lange can aluminium capacitor!
I saw on the net ELNA capacitor, aluminium lectrolytic capacitors for audio! somebody know them... ???
Old 31st January 2003, 05:04 AM   #5
coffin is offline coffin  Taiwan
coffin's Avatar
Elna for audio is good.
You can also find following brand:
EPCOS( ex Siemens) Sikorel series
RIFA (Evox) PEH169 series
BC component ( ex Philips) screw-in type
UCC screw-in type 36D or 36DX
Old 31st January 2003, 06:36 PM   #6
Yes but do you know how I can get this capacitor???
Old 31st January 2003, 06:42 PM   #7
Arold,
Call Ra-Elco In Salt Lake City. They have new in the box surplus Chem-Con 65,000mfd @63 volts can for 10.00 U,S, each.....they include the mounting foot too and hardware with each one!!
Hard to beat that deal. Call 801-467-7749 Ask for Brian or Robert.
Mark
Old 3rd February 2003, 07:00 PM   #8
Ok! I have the chance to buy audio capacitor from Jensen, a compagny from Danmark! This is capacitor for the audio application! They are MORE expensive than other capacitor, but I want to know if it is realy better to buy this kind of capacitor for my Ven V4 ???
Also, do 63V capacitor is enought for a 50V rail ???
thank you!!!
Old 3rd February 2003, 07:13 PM   #9
tiroth is offline tiroth  United States
What are the dimensions on those caps Mark?
Old 3rd February 2003, 07:27 PM   #10
For the:
15 000 uF 63V 35mm*70mm
10 000 uF 63V 35mm*50mm
6 800 uF 100v 35mm*70mm
why???
FS: Panasonic 22UF, 63V SMT capasitor gabanyayaya Swap Meet 0 10th May 2009 11:31 AM
krell ksa 50 capasitor help needed beckypumps Solid State 26 20th January 2006 07:57 AM
Sprague capasitor id morfeas Tubes / Valves 7 13th March 2005 11:44 AM
capasitor tze-hao yen Pass Labs 0 5th March 2005 03:20 AM
Page generated in 0.19499 seconds (44.00% PHP - 56.00% MySQL) with 11 queries
