Does anybody have an idea, how can be measured DC component in primary winding of PSU transformer? I hope it's possible without expensive equipment?
I like everything, but mediocrity |
#2 |
diyAudio Moderator Emeritus
Kiril,
Check out this thread: Transformer Hum?! STOP IT! With a bridge rectifier and capacitor in one side of the mains supply only, you should be able to measure any DC present across the electrolytic capacitor Cheers, |
#3 |
How do you think?
Will this be good? If you measure positive and negative voltage across resistors difference between them will (may be) equal to DC voltage in AC outlet. |
#4 |
Electrons are yellow and more is better!
I think you guys have misunderstood the question.
The question is how do I measure the DC part in the AC signal? My suggestion is simply to switch the DVM to DC but some (all?) may have some voltage limiting so the reading MAY be wrong. One trick to avoid this is to attach an external LP-filter, 100k plus 1 µF as a start. This filter reduces the AC part of the signal you want to measure.
/Per-Anders (my first name) or P-A as my friends call me |
| ID of component | Organist | Solid State | 10 | 2nd August 2007 06:52 PM |
| What is this component used for? | Mrpong | Parts | 6 | 31st August 2004 11:15 AM |
| what component do I need? | Raj1 | Pass Labs | 1 | 4th January 2003 10:20 PM |
| Page generated in 0.05950 seconds (79.89% PHP - 20.11% MySQL) with 11 queries |
