Hi to everybody!
i'm doing researchs on the forum about the output potentiometer for the Aleph P1.7 I came across to this: -Output pot suggested value is about 1-2Kohm - Since i'm going to build a resistive with a rotary selector ,i found negative feedback My 3 questions are: 1) can anybody give me an insight about the different configurations for latter potentiometer and which one is the best for this purpose or in general? 2) if i put the potentiometer on the output, is it not gonna be a problem for the output impedence that goes to drive a power amp, since it swings so much? 3) can i have some suggestions on a very good rotary switch to use for this project? i was thinking about Elma rotary switches (i think the same used on the renowed and very expencive DACT) ,but a couldn't find a good place where to buy a double 23 poistion or so. Thanks in advance for al the kind advice. Best Regards, Stefano.
Stefano |
#2 |
i haven't seen any post at this 3d....
pleaseee Helppp How can i make a 1.2K output 23 steps latter attenautor? How can i evaluate the value of the components? Please Help..
Stefano |
#3 |
To calculate the resistor values, maybe this is helpful?
Look at the bottom of the page. http://www.penguinlovers.net/audio/Attenuator.html
http://www.blogotheque.net/-Concerts-a-emporter- |
#4 |
I used the electroswitch brand and I had no problems with it. I never got a loose or bad connection.
I am not fond of switches that rely on bent metal to spring load the contacting force, but I suspect all commercially available rotary swithches are mechanically similar. JJ |
#6 | |
The value are set fot 10K 23 steps...if i try to change any of this par nothing happens...
Stefano |
#7 |
i have one thing to ask, if possible, hope somebody will give me an answer:
since i decided to use the latter stepped attenuator as output volume control, i was thinking to take off the cicuit, referring to the Aleph 1.7 service manual,the resistors R72(100) and R64(4.75K). I would like to know, what a good value would be for the potentiometer in this conditions. Just making a simple analysis, if in the original circuit an optimum value would be around 2K....without this two resistors a good value would be 1.5K. Is this calculation correct for you guys? Do i have any drawback by taking this 2 resistors off from the cicuit and replacing with a corrisponding value with the Out attenuator? Thanks in advance. Best, Stefano.
Stefano |
#8 |
Good quality 10K volume attenautor seems hard to find in HK.
If use 100K, any affect of the output gain and impedence? ( I have much 100K ALPS attenautor remain by other project) |
#9 | ||
#10 |
If you are interested....
I have a mint condition 10K FULLY balanced stereo DACT attenuator. I'd be willing to sell it for $180usd plus shipping. Here's a link to a picture of the DACT CT2 Balanced 4 deck attenuator. http://www.dact.com/html/attenuators.html -David |
| WTB: Aleph Output boards/Aleph-X | rchua77 | Swap Meet | 0 | 31st March 2008 04:56 AM |
| i know many times....output potentiometer | Stefanoo | Pass Labs | 13 | 24th December 2007 08:11 AM |
| potentiometer pass aleph 1.7 | P270 | Pass Labs | 7 | 16th November 2005 05:28 AM |
| Aleph 2 DC output | lawka | Pass Labs | 2 | 23rd July 2005 06:17 PM |
| Low output on Aleph 2 or... | Pboden | Pass Labs | 18 | 4th December 2004 01:47 PM |
| Page generated in 0.09943 seconds (85.04% PHP - 14.96% MySQL) with 10 queries |
