First Pass project, need Aleph-M PSU advice please - Page 2 - diyAudio
Old 4th May 2007, 03:39 AM   #11
MEGA_amp's Avatar
At 2.7 amps per channel, I'm also dissipating about 58 watts per output transistor. Just make sure you have enough heatsink if upping the bias is in the plans.
-john
Old 3rd June 2007, 07:42 PM   #12
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
What transistors?Can they take it?
Regards ke
Old 3rd June 2007, 08:08 PM   #13
Magura is offline Magura  Denmark
Magura's Avatar
You can approach 100W per device (IRFP240) if adequate heatinking is added to the equation.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 4th June 2007, 03:47 AM   #14
MEGA_amp's Avatar
Each IRFP240 had its own 12"x9.75" heatsink.
Old 12th June 2007, 11:25 AM   #15
ssmith is offline ssmith  Kenya
Hi again and sorry to bother.
I'm now stuck on what PSU caps to use --
1. a small number of 22,000uf/33,000uf screw terminal large can caps (like Cornell Dubilier)
2. a larger number of 10,000uf 35v snap-in caps (like Nichicon KG)
3. an even larger number of Panasonic FM 1800uf/35v caps (not too expensive from digikey).
The cost works out to be roughly the same, and I don't mind option#3 being a bit of a PITA to install and wire up, though I'm wondering if it would be worth the extra effort? From what I've gathered from searching here many people suggest using lots of smaller caps for low ESR and higher ripple, while others swear by the superiority of large cans.
Your thoughts would be appreciated.
Pass Aleph 4 Project out !!! promitheus Pass Labs 28 8th August 2010 08:40 PM
Pass Labs BZLS and Aleph 2 Clone project for sale qwertyl Swap Meet 0 9th September 2008 04:11 PM
Pass Tharagard A75 vs Pass Aleph 1.2's daly41k Pass Labs 7 18th February 2007 04:10 PM
pass aleph P VS pass X2 first version perusicchio Pass Labs 10 5th March 2004 11:06 AM
Pass aleph 3 project promitheus Pass Labs 90 9th August 2001 08:58 AM
Copyright 1999-2017 diyAudio
