Old 1st May 2007, 01:58 PM   #1
same is offline same  Italy
Default Matching Aleph 30 mosfet
hi,
for match mosfet is better use the source current that is in real life.
Than, is correct testing input mosfet with 12mA and power mosfet with 670 mA?
giorgio
Old 1st May 2007, 04:42 PM   #2
wuffwaff's Avatar
yes,
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 2nd May 2007, 10:02 AM   #3
h_a is offline h_a  Europe
h_a's Avatar
Since the input fets are biased with 10mA and the output mosfets with about 500mA I would say that your ordinary matching at 12mA and 670mA is perfectly fine.
Matching even closer to the real circuit values won't bring substantial benefit, but of course would be ideal.
Cheers, Hannes
Old 2nd May 2007, 11:00 AM   #4
EUVL is offline EUVL  Europe
I dare to disagree.
The fact that 2 transistors have the same Vgs at one current does not guarantee they are identical in their Vgs vs Id characteristics. If you measure enough over full range, you would know what I mean. Also the thermal sensitivity does vary (i.e. room temperature match does not guarantee match at working temperature.)
Would the amp work ?
Yes. But it would not have the minimal distortion that a full-range match under working conditions would give you.
Just my 2 cents,
Patrick
Old 2nd May 2007, 06:04 PM   #5
wuffwaff's Avatar
as far as I understood the 12mA and 670mA are the real circuit values.
William
Old 2nd May 2007, 07:46 PM   #6
The one and only
Nelson Pass's Avatar
True, although not a big issue. To minimize this, use devices
from the same lot code as well - they tend to be more identical
given the matched Vgs.
Old 3rd May 2007, 05:32 AM   #7
I agree; but this applies more to the IRF parts than other MOSFETs, e.g. Toshiba (both MOSFETs and JFETs).
Patrick
Old 3rd May 2007, 06:03 AM   #8
Formerly "jh6you". R.I.P.
Babowana's Avatar
Patrick
Okay . . . which Power MOSFETs of Toshiba are best useful?
Meanwhile, I liked Hitachi 2SK135 and 2SJ50 times ago.
Old 3rd May 2007, 08:01 AM   #9
I use 2SK1529 to replace IRFP240, but you need to change something to suit the lower Vgs. There is also a complememnntary part 2SJ200.
Similarly, 2SK1530/2SJ201 can replace IRFP250/9250 with adaptation. Then there are 2SK2013/2SJ148 which are similar to IRF610/9610, again with adaptation.
The list is endless ......
Patrick
Old 3rd May 2007, 09:46 AM   #10
I think that are real circuit values but maybe is not so.
Hannes say that correct values are 10 mA and 500mA.
It's ok?
giorgio
Matching MOSFET's for Aleph 2 Thago Pass Labs 4 5th June 2007 08:05 PM
MOSFET Pool for Matching Qs (Aleph X or Other)? lgreen Pass Labs 9 16th December 2004 03:25 AM
Aleph 5 (Mosfet matching time) billy Pass Labs 3 18th January 2003 03:32 PM
Aleph 5 (Mosfet Matching) billy Pass Labs 3 17th January 2003 03:18 PM
Matching MOSFET for Zen V4/Aleph 5 ??? PsykoK Pass Labs 5 26th September 2002 10:04 PM
Page generated in 0.10519 seconds (74.74% PHP - 25.26% MySQL) with 10 queries
