Threshold S/550e Bias advice
Old 28th April 2007, 02:09 PM   #1
Barry1 is offline Barry1  United States
Unhappy Threshold S/550e Bias advice
Iím an amateur and need some help with setting the bias on a newly acquired Threshold S/550e. I have a manual & related info for Threshold amplifiers with the same topology, but no specifics for this one.
Iím guessing the amp needs biasing because the heat sinks are running at 31 Ė 35C even after an all night warm-up and Ĺ hour of playing time. The operating manual I have is for all the Stasis amps, S/350e to 1600e, class A/AB, as well as the pure class A, S/4e through S/12e. It gives no S/550e biasing instructions. However, in another manual posted on NPís website it says, Ďthe E series amps are designed to run at 45 -50 degreesí, but the amps referenced are the Class A varieties & the bigger A/AB 1600e.
The schematic for the SA12e shows only one variable resistor, P1, a 10K trimpot, in the front end circuitry (which I hope I attached). That must set the bias, right?
Iím assuming I would use standard procedures adjusting that trimpot and taking my readings across one of the 1 ohm emitter resistor on the final output stage rechecking again in another 5 minutes or so.
I only have bias voltages for an S/500, the earlier model, which are 100mV cold and 75mV hot. Do these values sound right? Any other related advice?
If you have something to e-mail related to this Iím at: barrysandy@comcast.net.
Thanks for your help! Barry
Threshold S/550e Bias adviceHide this!Advertise here!
Threshold S/500 bias set up anyone? stevieg123 Pass Labs 31 24th August 2016 05:31 PM
Threshold S/550e to SA/4e conversion? Barry1 Pass Labs 2 1st January 2009 04:43 PM
Threshold SA4/e bias nchelazzi Pass Labs 2 16th June 2008 08:10 PM
Threshold S/550e Service Manual Barry1 Pass Labs 10 24th May 2007 12:35 PM
Threshold S/550e Info EchoWars Solid State 7 9th July 2006 06:03 AM
Copyright ©1999-2017 diyAudio
