Old 20th April 2007, 11:25 AM   #1
Mywing is offline Mywing  Italy
Default Minimalist diy preamp project
Hi folks,
after I red many threads on Pass diy, I decided (thanks Taeke and Jurgen, you convinced me...) to build a preamp myself.
My idea it's for a most simple possible project...
I think to realize a preamp with only one line input for best quality possible.
Which Pass project could I use? How could semplify it for obtain only one line input?
Thanks for suggestions and have a fine weekend,
Nino
Old 20th April 2007, 11:32 AM   #2
flg is offline flg  United States
flg's Avatar
BOZ?
Old 20th April 2007, 02:20 PM   #3
Sonusthree's Avatar
Do you want to go passive or active?
Obviously passive is much much simpler but it's all down to personal preference.
What is this preamp feeding?
Old 20th April 2007, 04:15 PM   #4
230V
Greets
Old 20th April 2007, 05:05 PM   #5
cviller is offline cviller  Denmark
cviller's Avatar
Originally posted by Mywing
230V
Greets
I think the question was about your power amp - what kind of power amp do you want to drive with your preamp. Do you have any special requirements?
Old 20th April 2007, 05:20 PM   #6
I've an ARC D115 2x115 W tubes amp.
But I should like build a polyvalent preamp which works well with tubes and SS (I think I'll realize in a short future also a diy Pass/power...)
Greets,
Nino
Old 22nd April 2007, 05:12 PM   #7
JC Fardo's Avatar
I would narrow my options to BOZ SS or
DuoPre
I´ve used BOZ to drive Borbely Audio Servo 50 monoblocs with excelent results.
Cheers
Jose Carlos
Old 23rd April 2007, 05:54 PM   #8
Well, I'm a bit confused how, I think, all you when started your diy approaching.
I've received some suggestions: Aleph P, Boz, Bosoz, X-Bosoz, X-Pre from TwistedPear...
Who'll be so kind to explain to me differences between them? Wich is best in sound quality? Maybe Aleph... but is it more difficult to build than others?
And then, what are exact differences etween Boz and Bosoz?...
When I'll decide which plan to realize, many many many other questions will arrive...
Thanks & cheers,
Nino
Old 23rd April 2007, 09:24 PM   #9
If you expected a single answer, you were bound to be disappointed.
Without knowing how comfortable you are with a soldering iron, it's difficult for anyone to give you a reasonable answer. One man's simple is another man's nightmare of complexity.
All things being equal, perhaps a BOSOZ would be a good choice. It's not terribly complicated and gives you at least the option of balanced outputs, should you decide that you want to go that route.
Grey
Old 23rd April 2007, 09:35 PM   #10
Thanks Grey,
I don't need balanced output; is this the difference between Boz and Bosoz?
Nino
Minimalist Mosfet amp Spiny Solid State 13 11th March 2008 06:40 AM
Minimalist DAC: is this possible? beppe61 Digital Source 12 27th July 2005 09:08 AM
Minimalist balanced phono preamp? leadbelly Analogue Source 10 17th April 2005 07:08 PM
Minimalist A/B fet amplifier plp Solid State 24 8th June 2003 11:58 PM
Page generated in 0.09924 seconds (77.90% PHP - 22.10% MySQL) with 10 queries
