Hi.
After living, with my LeachAmp since 2001, I decided to go crazy 1. In the part's list of ZV4 the value (and the digikey value as well) say's C8, C10 = 0,47 uF, but when i have a close look at the picture of the board, it say's 0,22 uF look here PICTURE or am i missing something ? 2. When planning on running this setup as 2 x mono blocks balanced, i need 4 pcb ? 3. I mean, when looking at the board, it say's +in and -out, so all i have to do, is make four equal, and use 2pcs. for +in / -out and 2pcs. for -in / +out .Right ? One of each in each monoblok ofcause ! 4. At the time writing, my BoSoZ, is running unbalanced, with a stereopot attached at the OUTPUT. Well i haven't got any balanced source's (and don't plan to), but if i move the stereo-volumepot, to the INPUT side, i guess the thing will work, feeding the balanced not yet buildet ZV4 fine. Right ? ![]() 5. I have been reading about the 'buffer for blues' HERE But really i can't figure it all out... I have some spare 2sk170BL + GR types, could they be used ?. And how do i connect it to, the ZV4 circuit ? (There are some deviations on the schematic Nelson posted in the thread, compared to the ZV4 circuit) Well it's 5 quistion's Jesper
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp. |
#2 |
The one and only
1. C8 and C10 are just high frequency decoupling caps - use any
value that makes you happy. 2. You need 4 pcb. 3. Yes. 4. More or less, right. 5. Buffer for Blues uses P channel JFET. Try a 2SJ108 or similar
#3 | |
Thanx... For clear reply's.
About the 2sk170, i forgot it was a n ch. - sorry for that ...Quote:
#4 |
Yes there is! Leave the pot on the output side. That way you attenuate the noise generated by the pre-amp, othervise you will only attenuate the signal, and have max. noise at all times.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#5 | ||
THIS is from the ZV4 paper's : Quote:
Anyway i would like to tell, that the reason, i would make a balanced set, is that i have some 'heavy' loudspeaker's to deal with. Thoose bear's really give me some punch when playing loud !Attached a picture of my 'Bears'
#6 |
Since the ZenV4 "just" gives 25 watt's, why not opt for an Aleph 5? 60 watt's will surely bring you a lot closer to a dynamic sound on those speakers!! As it happens, I have a pair of Aleph 5 boards, that I dont need anymore
Steen
#7 |
Steenoe you got mail !
#8 |
Ha ha, hate to say I told you so
Magura
#9 |
Magura
![]() Well, The last word haven't been said yet... Jesper
#10 | |
Magura
| GND quistion BoSoZ | lykkedk | Solid State | 2 | 7th November 2004 06:46 PM |
| Leach Amp protection quistion | lykkedk | Solid State | 3 | 3rd January 2004 04:26 AM |
| BoSoZ Gain, P1/P2 etc... Quistion's | lykkedk | Pass Labs | 9 | 3rd January 2003 06:37 PM |
| Balanced line stage, quistion's + unbalanced | lykkedk | Pass Labs | 4 | 19th December 2002 11:58 PM |
| x-bosoz as a buffer stage | jjacks4x | Pass Labs | 1 | 5th December 2002 02:28 PM |
| Page generated in 0.11348 seconds (81.27% PHP - 18.73% MySQL) with 11 queries |
