Old 18th April 2007, 03:25 PM   #1
Send a message via ICQ to AudioAngel
Default Balanced filter stage with BOSOZ
Hello,
I want to use the BOSOZ as line amp after a filter stage. Im working completly balanced. So if I want to use a filter in front of the BOSOZ has it to be done in a different way than in the unbalanced version or is it just doubling the circuits each equal to the otherside retaining the connections to ground and the feedbacks coming from the final buffer stage?
Raphael
Old 18th April 2007, 06:22 PM   #2
The one and only
Nelson Pass's Avatar
Either way. You can drive it single-ended off a filter or you
can drive it balanced with the output of two filters. For this
circuit, balanced is better performing, and if you want best
performance single ended use a constant current source to
bias the two Mosfets to the negative rail.
BOSOZ Balanced Attenuator Set-up hifimaker Pass Labs 5 2nd February 2005 03:25 AM
Balanced DC servo for balanced stage ? CheffDeGaar Solid State 8 9th July 2003 02:39 PM
BOSOZ balanced connectio BBB Pass Labs 5 3rd April 2003 11:53 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
Grounding thev Balanced line stage(BoSoz) Amj_ciron Pass Labs 21 16th July 2002 12:22 PM
Page generated in 0.06157 seconds (76.26% PHP - 23.74% MySQL) with 10 queries
