this is my attempt to create such a selector please comment my design
#2 |
This is from a plan am working on. It can be used to switch 2 balanced channels or 4 unbalanced channels between 3 sets of inputs. However I found something that works better for me so I’m dropping it.
Leve |
#3 |
what did you found??
you mean not to use relays? |
#4 |
I’m using latching relays instead. It’s like a normal relay except the contact is magnetized so it sticks to what ever side it’s pulled to by its two coils. They only need a pulse of power to switch. So I can use 3 momentary push buttons on the front cover to switch between channels, I think the project looks and feels classier that way. I would never put ss junk in the signal path unless it’s absolutely needed. The trick to the whole thing is how to get the other relays to come back up (unlatch) when I new one goes down (latches). I’ll give you a clue it’s all done with diodes, very similar to what I have in the PCB pick I posted.
Leve |
#5 |
i tought about mechanical switches to unlatch them but dropped that idea
will try some different in the evening |
#6 |
use another relay to unlatch them??
| input selector kit: relay: is this something oke ? | then_dude | Solid State | 0 | 23rd June 2009 11:36 AM |
| Relay input selector wiring help needed! | zoranaudio | Solid State | 1 | 31st July 2008 06:58 PM |
| Relay switched source selector | mike_steinert | Chip Amps | 2 | 3rd March 2007 07:22 AM |
| Relay - Selector Swich | ruangrit | Solid State | 0 | 5th September 2003 04:58 AM |
| relay input selector | macgyver | Pass Labs | 6 | 7th October 2002 07:33 AM |
| Page generated in 0.08002 seconds (70.83% PHP - 29.17% MySQL) with 11 queries |
