Hello folks,
I listen to music with my Aleph 30 amp in a mid-size (4x4,50 m.)room. My speakers' sensibility is 87 db but in my room the "30" works enough well. Now I could change listening-room to a 8x4,50 m. one, and my "30" is not enough powerful for a good listening level. (I heard an Aleph 60 but it's not so magical as the "30"...) Which between old Threshold/Pass' products has same musical characteristics but more powerful? Could the N.P.'s vintageamps expertises make a subjective quality classify? 400A, Cas1-2, 4000... And then, I use a tube Arc preamp which works well with the"30" but I would complete a couple with a NP vintage preamp. Which would be a best buy? NS10, SL10...?... I hope someone of you would spent a bit of his time to clear my doubts. Thanks a lot, Luigi |
#2 |
There are various ways to approach this. My first suggestion would be to build a 60W or 100W Aleph...but increase the bias. This will require serious heatsinking. The stock Alephs already generate a lot of heat, but increasing the bias will generate even more.
Yes, the power supply will need to be robust. The 30W Aleph had the highest relative bias of all the Alephs. Given that increasing the bias current makes an amp sound better, this could very well be why you prefer that amplifier. I have done a great deal of fiddling with the bias on Aleph 2s (the 100W monoblock version) and can say that increasing the bias on Aleph 2s results in a warmer, more tube-like sound. I generally run mine about 10% above stock bias. The heat dissipation isn't a problem for me because mine are water cooled. I can dissipate most any amount of heat that the output devices can generate and stay within their SOA. Others are more likely to use air cooled amps. Start with desired power, then work backwards, choosing the circuit that will generate that general amount of wattage, then looking at power supply design and heat dissipation. Grey |
#3 |
The one and only
In any case I don't see a reason to rush out and replace
your ARC preamp.
#4 | |
Care to provide full details of your water cooling system (with Photos)? Or you have already done so? (I think a lot of people will be interested as it is expensive and difficult to get suitable heat sinks, especially for high power ones.) |
#5 |
Search?
Grey's watercooled Aleph thread No pics around, although myself and I'm sure a few others wouldn't mind seeing some pics of Grey's creation. Heck, i'm sure I could find an "old" digicam and send it to him. He's been holding out for toooo long.
#6 | |
Good idea! Thanks for the link! |
#7 |
I dont se the reason for you to change amp - I would recommend you to try and listen to your system in the large room, but with your speakers positioned to play in the short direction of the room - so you will have about 3 meters between the speakers and your ears (assuming you have the speakers a meter or so from the wall and about the same with your head).
This have prooved great results in my room, instead of playing in the "long" direction, which is what you se most of the time. This way difractions from the side walls hits your ear much, much later. And, your given that your speakers are about the same distance as in the old room, mabye the A30 is enough ? BTW - sound will also change with more output transistors, so it is proberbly not all about bias and cooling.... Kind regards Hans
"Calculations? We don't need no stinkin calculations! We just make them really big!" Quote: Nelson Pass |
#8 | |||
Thanks for suggestions guys, but...
Anyway I would you suggest me a more powerful NP amp to search between Cas, 400, 4000 or other Cheers, Luigi |
#9 | |
...the problem - once you start you can't stop.
Crazy Yankee. |
| NE5530N op amp or substitute? | javey | Parts | 25 | 25th May 2012 08:54 AM |
| irf244 substitute | hudnes | Pass Labs | 4 | 15th September 2004 09:09 AM |
| tr substitute | dexter | Solid State | 5 | 29th April 2001 02:53 PM |
| Page generated in 0.11652 seconds (81.59% PHP - 18.41% MySQL) with 10 queries |
