| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hey friends. I maked a mp3 player using winamp plugin. ( 16 X 2 LCD )
No i wanna put some text on my LCD when system is booting. Is it possible ?
pasan... |
#2 |
You could use a microcontroller which sends it a string on power up and then "disconnects" itself so winamp can control it later (might depend on how you have it connected, if it can override the bootup state of say the parallel/com port).
Or better yet, talk through the micro over rs232/usb when the computer has booted, but let it do its own thing otherwise. but I believe you are looking for a simple solution, which this isnt.. hm it might be possible to modify the bootup procedure to send out a message. but then you still woudlnt see it until say half way into boot. |
#3 |
Hey bro i saw some one use LCD print or something like that to print some text on LCD when it is booting.
How to use a pic to print someting and when system is boot automatically take over to winamp?
pasan... |
#4 |
If you hunt around, there's plans for using a microcontroller to emulate those serial interface LCD modules. If the source code is provided, you could modify it to display some default message until the computer says something over the serial line.
It's possible that there are motherboards out there with BIOSes that have been patched to support LCD displays. I've got an old Wyse '286 that came with an LCD front panel display. |
#5 |
Im using SMARTIE for do that thing.
pasan... |
#6 |
Maybe you're better off just speeding up Windoze to make it boot faster. Check out the forums at MP3car.com for some good info.
You might also want to consider running a DOS player without Windows. MPXplay is still being actively developed, and has just about any feature you could ask for (including LCD display support and resuming). http://www.geocities.com/mpxplay/ |
#7 |
Yes MPXPLAY is also a very good software. Now I move to this http://www.markuszehnder.ch/projects...ugin/index.php. Its very easy to use. But its stil need windows.
Thanks for ur Kind help
pasan... |
| lcd Character Module | karma | Everything Else | 4 | 12th December 2007 06:30 PM |
| chipamp sound character | BaronGijs | Chip Amps | 11 | 1st March 2007 12:16 AM |
| Asian character interpretation help sought | Geek | The Lounge | 5 | 2nd February 2007 11:21 PM |
| The sonic character of different PCB materials (or P2P) | Bricolo | Parts | 5 | 30th January 2004 05:21 AM |
| Page generated in 0.09143 seconds (74.77% PHP - 25.23% MySQL) with 10 queries |
