| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi all !
I`m starting to build SKA GB300D , my first serious audio project , and I need some help to choose right PSU capacitors. I can get : Mundorf HC 100x47000uF Epcos B41456B9479M000 Vishay EvoxRifa Aerovox Black Gate are too expensive, Epcos Cikorel - hard to get, but pepole are telling good about this cap`s... It`s possible to go with stuff described above, or Cikorel / Black Gate to get the best point ? Any suggestions ? |
#2 |
" ... Mundorf HC 100x47000uF ..."
Assuming you mean that this part is 100 volt max rated, and your PSU has less than 65 VDC rails, then go for it. (I always use electrolytic caps with a voltage rating at least 150% of projected rail voltage, that way I can use any decent electrolytic without worry about a need for the more expensive stuff.) Best advise, always use plastic snubbing caps across (parallel to) the PSU electrolytics = MKT (or polystyrene equal) are as good as they get without breaking the bank. Precision eyeballing = rule of thumb = 0.01% to 0.1% of electrolytic values works about right for g'ment work. Example: 20,000 uF electros could use plastic snubbers around 2.2 uF to 22 uF MKT / 150 volts should do it. (There is lots of online articles about this. TI and Analog Devices engineers use close coupled plastic caps right across the power pins on op-amps in order to get those great specs. = 1000 uF on these op-amp PSU rails indicates usage of 0.1 uF (100 nF) plastic MKT ... results in reduced distortion numbers quite a bit better than expected.)
Over compression is a problem with modern CD recordings |
#3 |
Thank`s
I meen to use 100V versions from any of cap`s above. Do u used Mundorf`s HC ? |
#4 |
" ... Do u used Mundorf`s HC ? ..."
Probably not, but can not be sure. I have used so many different brands of caps and other parts that I can not be sure. (2500+ computers, several dozen amps, all manner of esoteric industrial and lab gadgets.)
| help to choose a good osilloscope | thanhtranau | Digital Line Level | 2 | 2nd July 2009 09:45 AM |
| Cathode Bypass caps - how to choose? | JesseG | Tubes / Valves | 15 | 30th December 2008 12:55 AM |
| Aleph P 1.7: Need help to choose som caps | roger-k | Pass Labs | 2 | 16th November 2005 01:13 PM |
| help choose between these two caps for PSU | ronardi | Parts | 3 | 22nd March 2005 02:23 AM |
| [help] choose the good one! | PsykoK | Pass Labs | 1 | 19th September 2002 06:05 PM |
| Page generated in 0.07510 seconds (72.96% PHP - 27.04% MySQL) with 10 queries |
