Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st March 2007, 10:44 AM   #1
Gveto is offline Gveto  United States
Lightbulb Please help me find the part I need for this unique application!
Greetings,
In the attached pitcure, you will see a white female plug whose life began as a CPU fan wire. These adapters use the .1" spacing to receive 3 pins from the motherboard. In the photo I have mated the plug with a MOSFET, which uses the universal spacing as well.
My thought are to use this sort of connection between my breadboard, and a separate bench heatsink that has the transistors mounted on it. During development, this system can ease the burden of trying many different OPS schemes. Not to mention, that the transistor leads are kept pristine ready to go in your next project.
The only glitch has been trying to source these plugs (with leads?)
Or at least determine the correct name or type of plug to be used in this situation.
Any help you can give me is very much appreciated.
Thanks,
Dan
Old 21st March 2007, 05:15 PM   #2
Fenris is offline Fenris  United States
Best place to look is alot of PC mod stores. I happened to have a window open and saw this:
http://www.mnpctech.com/3pinfanextension.html
http://www.xoxide.com/wireadaptors.html
http://www.frozencpu.com/cat/l3/g36/...ors-Page1.html
http://www.svc.com/fan-cable-adapter.html
Listen to the music through the stereo, not the stereo through the music.
Old 25th March 2007, 08:29 AM   #3
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
I use this system my self.
The plugs I use are from Molex, and can be supplied with wires
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 25th March 2007, 05:03 PM   #4
Chartal is offline Chartal  Canada
Digi-Key have some with solder lead.
Molex WM3001-ND
Molex WM3101-ND
Molex WM3201-ND
Molex WM3212-ND
Molex WM3223-ND
Molex WM3234-ND
Unique Autosports JDDCo Car Audio 19 15th January 2009 01:19 AM
Guido Tent hard to find-->Part 2 Ryssen Digital Line Level 10 14th January 2009 08:08 PM
Unique or odd uses for the diyAudio CCS boards Geek Tubes / Valves 1 12th December 2006 02:45 PM
can't seem to find these part numbers, any ideas??? Htguy Analogue Source 0 13th July 2005 06:13 AM
Unique request: 10MHZ (-3db) pre-amp Gomer Solid State 3 24th March 2003 09:55 PM
Page generated in 0.08369 seconds (74.46% PHP - 25.54% MySQL) with 11 queries
