| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Can anyone help me out, im trying to find some IRFZ44N VDSS = 55V, RDS(on) = 17.5mW, ID = 49A, MOSFET, N Channel transistors for my car amp, only everywhere i find theyre discontinued, what alternatives do i have to choose from ?
Jå¢kº - ²K5 |
#2 |
Off the top of my head, IRFP044 is about the same, just a TO-247 package. If you got room for the bigger package it's an easy solytion, as it's readily available and cheap.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#3 |
Thanx for that Magura, i will check RS online for a price
Jå¢kº - ²K5 |
#4 |
BUZ11 variants may also work. I've seen them interchanged in some car amps. Check the data sheets; there are small differences...
Regards, Gordon.'
Speaker Design, Restoration and Repair- since 1985. |
#5 |
Am I correct in believing that as long as the replacement MOSFET is of larger values it should work ?
Oh a couple more questions I forgot to ask first time round, 1, what electrical equipment besides audio equipment are they used ? 2, I have some Photoelectric Proximity Switches & want to put them to use somewhere, the thing is they only kick out 150mA once triggered, is there some relay that can be switched with such a small current ? or maybe I could amplify the voltage from 150mA to a more useable voltage ?
Jå¢kº - ²K5 |
#6 |
Fairchild makes an equivalent HRFZ44N, available at digikey for $1.20 apiece. There are better ones you could get for increased efficiency though, like the HUF75339P3 (10mohms ON resistance), though it has a slightly higher gate charge, so there is a very very slim chance that it might not be compatible with the driver, depending on frequency and power dissipation in that driver. I would go with the latter, but then I am an experimenter...
good luck |
| JBL D130 best alternative(s)? | DGGomez | Multi-Way | 1 | 15th August 2008 11:32 AM |
| n/p Mosfets vs depletion mod mosfets | marcello7x | Car Audio | 6 | 4th October 2006 05:01 AM |
| alternative | Dj BASS AMP | Solid State | 0 | 9th November 2002 09:00 PM |
| Alternative's | pete.a | Parts | 1 | 28th July 2002 12:57 PM |
| alternative mosfets for Zen amp | punk | Pass Labs | 10 | 10th February 2002 01:35 AM |
| Page generated in 0.08035 seconds (75.08% PHP - 24.92% MySQL) with 10 queries |
