Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Good sources for high-V (600V) Schottky diodes?
Old 20th March 2007, 07:47 PM   #1
GordonW is offline GordonW  United States
GordonW's Avatar
Default Good sources for high-V (600V) Schottky diodes?
Looking to upgrade the B+ rectifiers on my old HK Award A300 tube amp.
It'd need two 600v Schottky diodes, to do it right. 1 amp should be PLENTY, I'd think.
However, I've only found limited availability of these... nothing that was JUST right. Anyone got any good sources for these things? Basically, a standard "axial" configuration (ie, one wire out each end) would be best...
Gordon.
Speaker Design, Restoration and Repair- since 1985.
Old 20th March 2007, 07:48 PM   #2
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Why does this amplifier require schottky diodes?
Old 21st March 2007, 02:53 PM   #3
GordonW's Avatar
More graceful on-off characteristics than regular junction diodes... less switching noise. The characteristics of a Schottky more resemble that of a tube rectifier, but with much less voltage drop.
The HK originally had solid-state diodes... which had bypass caps on them, to try and snub the switching noise. With the Schottkys, there should be almost no noise TO have to bypass/filter...
Gordon.
Old 21st March 2007, 03:09 PM   #4
resident is offline resident
Account Disabled
search for the HFA08TB60
they're not axial though............ but too fast
Old 23rd March 2007, 03:41 PM   #5
serengetiplains is offline serengetiplains  Canada
serengetiplains's Avatar
Parts Connexion sells them.
Old 24th March 2007, 06:13 PM   #6
GordonW's Avatar
Found them. Cree 600v, 2A. From Digikey. Less than $2 each!
They also have 1200V; in this case, I only needed 400V minimum, so the 600V were perfect...
Gordon.
Old 24th March 2007, 07:11 PM   #7
Nice find, Gordon. Say, can these devices be paralleled, without more, for greater current handling?
Old 24th March 2007, 11:55 PM   #8
MatchASM is offline MatchASM  Europe
I would recommend against that, because if the junction voltage drops aren't exactly equal, the current distribution will be highly asymmetrical and thus you will not benefit from the parallel connection.
On the other hand, Schottkies have a lower voltage drop than regular diodes, so I would not expect them to heat up very significantly. Has anyone ever tried running these things "over spec"?
Old 25th March 2007, 03:47 AM   #9
jcx is offline jcx  United States
parallel with balancing resistors
semi diodes are going to be way lower impedance than any tube they replace
and don't count on exceeding power device ratings - the marketing guys would dearly love to put bigger # on the data sheet, they often get sneaky by specifying unrealistically optimistic heatsinking as is - cautious engineers often derate device operating conditions to <50% of the data sheet value
Good sources for high-V (600V) Schottky diodes?Hide this!Advertise here!
Where can I buy schottky diodes in Australia ? lordvader Parts 2 29th November 2007 09:57 PM
mandatory Schottky diodes ? coresta Class D 4 5th June 2007 01:52 AM
IR Hexfred diodes - HFA50PA60 600V, 50A spitz Swap Meet 5 5th July 2004 01:39 PM
Aleph-X builders LOOK!! HIGH-power (real!) dual Schottky diodes for sale cocolino Swap Meet 11 5th March 2004 08:56 AM
International Rectifier Schottky diodes KevinLee Swap Meet 17 30th June 2003 09:37 PM
Copyright ©1999-2017 diyAudio
