Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th March 2007, 05:54 PM   #1
Default Op amp current consumption - dual vs. single
OK, so when I read a dual op amp spec sheet, and it lists "absolute max ratings", and says +/-10mA supply current, is that for the entire DIP package (2 opamps) or is that per opamp? Part in question is NE5532. Thanks!
Old 20th March 2007, 07:46 PM   #2
If the spec says "per channel", it's per channel. If there's no such qualification, it's total.
10 mA total for a 5532 strikes me as about right.
Old 20th March 2007, 10:21 PM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: Op amp current consumption - dual vs. single
It is very, very unusual to list supply current under absolute max ratings. Are you sure you read it correctly? Wasn't it absolute max input current or something similar?
Jan Didden
Edit: Just checked it. It doesn't say 10mA max supply current. It says 10mA max input current. Supply current is 8mA typ, 16mA max for the two.
/Another new issue: Linear Audio Volume 3!
Aleph 5 single PS or dual? Leeuwarden Pass Labs 17 29th October 2009 07:44 AM
Use a single secondary x-former as dual PSU? pixworld Chip Amps 7 9th March 2009 12:32 PM
Class D - about current consumption from the supply - a question folks destroyer X Class D 6 18th August 2008 01:57 PM
Dukane IB3250 ("two-fifty") high current consumption handy Solid State 0 9th August 2004 04:14 PM
Max current consumption for P3A? deepanger Solid State 6 20th December 2002 02:11 PM
Page generated in 0.07609 seconds (68.00% PHP - 32.00% MySQL) with 10 queries
