Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th March 2007, 12:35 PM   #1
johnm is offline johnm  United Kingdom
johnm's Avatar
Default Non yellowing clear heat-proof lacquer???
Hi!
I'm planning to strip my pair of Quad IIs down to the bare metal, polish these up and apply a clear lacquer to protect the metal. They have both seen better days, and none of the components inside are original so I have no qualms about doing this.
I've read that lacquer when exposed to extremes of heat can have a tendency to yellow with age (even the so-called non yellowing formulas!). Obviously the Quad II puts out alot of heat, so I was wondering if anyone out there had any recommendations for a lacquer (available in the UK) that would do the trick here?
Thank you.
- John
Old 19th March 2007, 01:37 AM   #2
Geek's Avatar
Varathane has a spray clear topcoat that I understand will do this well. Fellow in the hardware store told me he coated his guitar amp chassis in the stuff and it has held up for six monts so far. Haven't tried it myself though.
Cheers!
Old 19th March 2007, 12:35 PM   #3
johnm's Avatar
Thanks for that I'll look into this!
- John
Old 19th March 2007, 12:46 PM   #4
mpmarino's Avatar
Although difficult to use safely, I think automotive clear coat would stay crystal clear under most conditions.
Other than that I would think a lacquer solvent based product would stand a better chance than water or oil based. IMHO.
Crazy Yankee.
Old 19th March 2007, 01:10 PM   #5
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
If you are not concerned about the originality, why not get the chassis chrome plated ??
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 19th March 2007, 01:22 PM   #6
pinkmouse's Avatar
Threads merged. Please don't cross post.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 19th March 2007, 07:08 PM   #7
johnm's Avatar
Sorry Pinkmouse thought I'd posted in the wrong place to get the most results so repeated the question in the parts section.
Thanks for merging :-)
Thanks also for the suggestions folks - will try the automotive route.
Love the look of polished steel, but think chrome plating is too bright if that makes sense - haha!
cheers,
- John
Old 21st March 2007, 02:43 AM   #8
redrabbit's Avatar
Not familiar with the Quad's case.....
What kind of metal is it ?
In any case, Varathane is an oil-base polyurethane, and will yellow with age. Looks great on wood though. Some folks think the yellowing over time adds character to the wood.
mpmarino is correct, automotive clear is a good choice.
Heat...think about it-- Put your hand on a black car sitting in the hot sun,..... .
*Almost always must be sprayed.
*Must also use the matching thinner solvent(s).
*Can be found in high gloss, semi-gloss and "flat" these days.
*Water thinnable versions are now becoming mandatory in some states.... everywhere eventually.
*Preparing and cleaning the metal is everything .
*Expensive.
*Looks great though.
There are too many products out there to recommend "one".
Dupont and PPG are the biggest.
Research your local auto repair supply stores, see what brands they carry.
If you are not up to spraying it yourself...
I once found a auto painting shop , walked in with a faceplate, and inquired "what would it cost to paint this..."
....when they found out it was for my DIY hobby, they happily painted it for $50.
My girlfriend could have had it done for free.
=FB=
Old 21st March 2007, 09:34 AM   #9
poynton's Avatar
There is also a process called 'chemical polishing'.
I don't know what it is exactly. I used to do some part-time work for a company that used the process on stainless steel. Whether it is only applicable to SS , I am not sure but the finish was superb.
Andy
Old 24th March 2007, 12:43 AM   #10
Series1 is offline Series1  New Zealand
There is a product called spar varnish or spar lacquer. It is intended for a fairly harsh marine environment and I have used it on aluminimum (motorcycle parts actually), it went on well via both brush and spraygun and has not flaked or yellowed over 4 years. The one downside for your use is that although it is clear and transparent it is not absolutely crystal/glassy clear.
Wood & Varnish cervelorider Construction Tips 107 6th December 2011 05:31 AM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 12:15 PM
Varnish on old transformer duderduderini Tubes / Valves 12 19th May 2008 01:20 PM
Page generated in 0.10422 seconds (79.42% PHP - 20.58% MySQL) with 10 queries
