Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th March 2007, 09:05 PM   #1
Default Doubt with Active Sub Controller
I was looking at project 48 on Rod Elliot's Page, and when looking at the schematic and the pcb i noticed that there are some electrolitic caps in the pcb that are not shown in the schematic...why is this? just to protect the circuit for being copied or they're not necessary or what?
http://sound.westhost.com/project48.htm#1
Old 19th March 2007, 11:26 AM   #2
One can only see two foil caps on Rod's PCB so is assume that four of these are used as the 4.7 uF coupling caps.
I have seen someting interesting recently: The original ELF patent has run out at least in Europe.
Charles
Old 19th March 2007, 11:34 AM   #3
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
I'd say they are just the power / bypass caps for the opamps. He does the same thing with the P88.
It will be the electros and some ceramics across the rails.
Old 19th March 2007, 09:44 PM   #4
ok guys but...should i put those electrolytics anywhere? or shouldn't i?!
Old 19th March 2007, 10:01 PM   #5
MJL21193's Avatar
If you follow the schematic exactly you will have no problem - there isn't anything missing. Disregard the electros in the photo as this is a pic of his prototype.
Old 20th March 2007, 04:09 AM   #6
rabbitz's Avatar
The prototype PCB is the same as the final ones he sells. C1 to C4 are signal caps and C5 to C9 are filter and bypass caps which are needed.
Full details are shown in the P48 construction article but you need to buy a PCB to access this info.
Old 20th March 2007, 03:25 PM   #7
macboy is offline macboy  Canada
The schematic is definitely missing power supply bypass caps for the opamps. You need some.
Old 27th March 2007, 07:32 PM   #8
REFUGE is offline REFUGE  United States
I'm looking at my P48 PCB and I see spaces for 9 caps and the circuit diagram shows 4. I wrote to Mr. Elliot asking for additional info re: the caps. He said the information is available on the secured sight which I have not yet found.
There are two caps #C7 and #C8 that are definitely the size and shape of filter caps.
What is the secured site he mentioned? Anybody know?
Old 27th March 2007, 10:11 PM   #9
And! I've asked for an active sub filter schematic here and the replies i got where about taking a look to that schematic, which is useless since there are parts missing. I need one of those filters, which also sum up left and right channels. Does anyone have a COMPLETE, WORKING schematic for a sub filter?
Old 28th March 2007, 04:51 PM   #10
OK, so first off you need to understand that P48 is probably not what you want unless you read the article very carefully and understand exactly how the circuit is designed to be used. It is not a simple crossover, it is primarily a very special EQ designed for use with a specific type of subwoofer. That is, a subwoofer which has been intentially built into a box that is "too small" (according to traditional design methods) so that its resonant frequency is higher than the frequencies it will be used at. If you try to use this circuit with a conventional subwoofer, you will not only be disappointed with the performance, but will also be likely to damage your subwoofer.
There are no fewer than 3 crossover projects on Rod's site, any of which could be used as a subwoofer crossover after the correct filter component values are chosen. In general, Rod's projects' schematics do not include a power supply, but he usually refers the reader to one of his power supply projects. In addition he rarely includes (necessary) power supply bypass capacitors in his schematics, but he includes them on his PCBs. Usually, all that you need to do is add a 10 uF 25 V cap between each of the two power rails and ground (one pair for each opamp), noting correct polarity of course. Other than that the circuits he puts up are generally functional as described in the articles.
Samsung 1602VFD For CDROM Controller & Remote Volume Controller slowgay Swap Meet 2 22nd November 2008 02:44 PM
doubt swaroopvg Power Supplies 0 1st July 2006 05:27 PM
Active Sub-Woofer and Controller frequency adjustment PetarLD Solid State 3 19th June 2005 04:50 PM
EAS/ELF doubt rs1026 Chip Amps 8 9th November 2004 06:45 PM
Page generated in 0.10803 seconds (78.14% PHP - 21.86% MySQL) with 10 queries
