| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have a transformer.....it puts out 5.00VAC and on the same wire 3.46VDC how does this work?
#2 |
your transformer has more parts inside than just windings = possibly some diodes and maybe a chip and a capacitor or two ...
Over compression is a problem with modern CD recordings |
#3 | |
#4 |
Some multi meters also have 'issues' with reading voltages properly.
the 5vac could be 'supply ripple'. the 3.46vdc could be measurement error of the meter. Load the plug pack with a small fillament bulb and then see what your meter says. (small bulb, say something like a 6v torch bulb) EDIT; if it is an actuall mains transformer with NO other components (diodes etc) then I garrentee your meters a cheap/nasty/faulty one) |
| Quick quick question ! | guitvinny | Pass Labs | 6 | 7th February 2007 04:20 PM |
| some quick help PLS | v1d9uy | Multi-Way | 4 | 11th January 2006 05:18 PM |
| Just a quick Q | VictorG | Tubes / Valves | 1 | 19th January 2004 03:15 PM |
| Page generated in 0.07865 seconds (67.36% PHP - 32.64% MySQL) with 10 queries |
